VG-99 - VG-99 Librarian backup help needed.
Started by stratblue, January 13, 2016, 01:30:59 AM
stratblue
Hi All.
I have a couple of issues with the VG99 so I'm going to backup the contents, initialise it then send all my sounds back. So, I just wanted to check that I'm going to do it right, I'm going to use the librarian but do I just need it in patch mode or do I have to go through all 4 modes to ensure I have a complete backup of the unit? Is there anything I've not considered?
Thanks, all.
It is wise to backup both patches and system settings. In the system settings the gk settings are saved.
Ideally you will want to perform four separate operations using the 4 possible "MODE"'s of the VG-99 Librarian
1 ) Set MODE to PATCH and save VG-99 Patch data
2 ) Set MODE to SYSTEM and save VG-99 SYSTEM data
3 ) Set MODE to GK SETTING and save VG-99 GK Settings data
4 ) Set MODE to FAVORITE SETTINGS and save VG-99 Favorites Settings data
Read the Roland Librarian Doc here
http://cdn.roland.com/assets/media/pdf/INFOCUS02.pdf
