VG-99 ASIO USB 64-bit not working on Windows 10.
Started by baatkarlo, August 16, 2015, 07:08:26 PM
baatkarlo
My VG-99 64-bit USB ASIO drive was working fine on Windows8.1, and with the free upgrade to Windows10, now its stopped working. Has anyone found a work around for this issue? The Win7 64-bit driver will not install on Win10 even under compatibility mode. HELP.
Eat sleep get up play. Eat sleep get up play. Eat sleep get up play.
baatkarlo
Alright so something happened with the latest Windows 10 Pro update on my Surface Pro 3. I turned on my VG-99 after turning on my Surface Pro 3 with the VG-99 USB cable hooked up to it this morning. After about one hour of working without noticing, I saw the VG-99 flash a message on its screen, "USB Connected". Totally unexpected, as I had given up on using VG-99 Librarian and Editor on Windows 10 Pro. So I said, what the heck, and fired up VG-99 Editor. It opened and showed "Getting Data" and pulled up0 the patch currently running on the VG-99 in the software!
Its working without any issues now. I'm currently downloading and installing "Upgrade to Windows 10 Pro, version 1511, 10586". Hope it continues working after this too.
https://www.vguitarforums.com/smf/index.php?topic=9763.msg118930#msg118930
http://www.rolandus.com/support/by_product/vg-99/updates_drivers/351094
UPDATE:
I successfully installed it but had to resolve one issue for VG-99 Editor midi setting. Please see my post in this page:
https://www.vguitarforums.com/smf/index.php?topic=16242.0
From the webpage:
VG-99 Driver Ver.1.0.0 for Windows 10
This contains information on the VG-99 driver compatible with Microsoft Windows 10.
Driver for Windows 10
Your computer automatically downloads the Windows(R) 10 driver from the Internet when a product requiring the driver is connected to the computer.
   For detailed information about the driver, check "Download File" at the bottom of this page.
   * Under normal conditions, the driver installation is completed in several minutes. It may take about 10 minutes depending on the Internet connectivity or if there are other drivers being installed for other devices.
   * A problem may have occurred if the device is connected but cannot be used after waiting for 10 minutes. Download the detailed information for the driver and refer to "Troubleshooting."
System requirements
Operating System
Microsoft(R) Windows(R) 10 ( 64-bit Edition / 32-bit Edition )
   * Windows 10 Mobile is not supported.
Computer
Windows-compatible PC equipped with USB port
   * Intel chipset is recommended.
   * The device may not perform to its full specs when used with an added USB 2.0 interface card.
   * This product cannot be used with a USB 3.0 port that is not compatible with USB 2.0 specification.
   * If this product does not work correctly when connected to a USB 3.0 port, you will need to connect it to a USB 2.0 port.
   * Even if connected to a USB 3.0 port, the performance of the product will not change.
   * This driver cannot be used in a virtual Windows environment, such as Hyper-V or Virtual PC.
   * Mac computers running Microsoft Windows are not supported.
Other
Internet connection
   * The Internet connection is needed to download the driver.
