VG-99 - chords
Started by ajvdn, April 11, 2008, 02:32:49 PM
ajvdn
This is the first patch I made with the "null" patch as a starting point.
It has a classic strat as COSM A, and a bass for COSM B
Chords are created by the Harmonist. You can choose your key with the F1 knob.
CTL1 is slow gear on/off
Regards,
AJ
ajvdn
I'm not trying to advertise chordie.com with this post. But I was playing two songs and this patch was brilliant. Even if you can't play, you can play these songs  ;)
I just can't get enough
http://www.chordie.com/chord.pere/hem.passagen.se/surftore/text/lyrics/depeche_mode/just_cant_get_enough_pro.txt
Just play the bass notes after you dailed in the right key with the F1 knob. During instrumentals (no singing) also play an octave (or two) above the bass note.
Martha (Tom Waits)
http://www.chordie.com/chord.pere/www.pjandphil.utvinternet.com/waits/MARTHA.TXT
I used the slow gear function, it gives more dimension I think. Ones again just play the bass notes.
You can also activate the 12 string simulation on channel A to give more sparkle.
Regars,
AJ
