VG-88 - Using Midi Controllers with the VG-88 Assigns
Started by brookesy, July 23, 2015, 01:38:19 AM
brookesy
Hi everyone,
I'm new to the forum and I was wondering if anyone is using a midi controller to control the VG-88's effects parameters in real time. I've seen no mention of it on the forum, if so could you share any experiences (either good or bad) you've had.
cheers
brookesy
use the same concept we use for other Roland  / Boss GK Processors  - fully explained here
https://www.vguitarforums.com/smf/index.php?topic=2951.msg111764#msg111764
Read
MIDI Controller Setup / Debug Strategies
and the VG-88 Vedit Editor - makes easy access to the VG-88's Control Assignments
https://www.vguitarforums.com/smf/index.php?topic=6455.0
Read the VG-88 Manual - search on ASSIGN - there are Eight  ASSIGNs, each can be mapped to have VG-88 FX  as TARGETS, and the SOURCE can be mapped to external MIDI CC# messages received from external MIDI Controller.
(Read docs here:
Programming Roland/Boss COSM FX
https://www.vguitarforums.com/smf/index.php?topic=88.msg141#msg141
Read VG-88 OM pages 31-32 that cover the details of:
Setting the ASSIGN Functions
I used a fcb behringer 1010 for a while when I had more gear worked fine controlled some fx parameters as well as an lexicon jam man and an electrix repeater and a line 6 pod,
I got tired of hauling so much stuff around but other than that worked fine as I can recall,
Still use the 88 for some gigs
brookesy
Hi Elantric,
I've read the link https://www.vguitarforums.com/smf/index.php?topic=2951.msg111764#msg111764 but it deals with CC and PC messages but as far as I'm aware the VG-88 deals with sysex messages only to change parameters or am I missing something.
Hi Brak(E)man,
I also own a FCB1010 and it's a great bit of kit. I was going to use it more as a stomp box and maybe use the 2 expression pedals to control the more important parameters.
Quoteas far as I'm aware the VG-88 deals with sysex messages only to change parameters or am I missing something.
Quote from: Elantric on July 23, 2015, 02:39:39 PM
Here are the possible VG-88 FX Targets for the ASSIGNS
Hands on examples of using Roland/Boss Control ASSIGNS are included in the docs here
brookesy
Thank you Elantric, I over looked this possibility. I will try it out tomorrow.
I was going to use the BC Manager for the BCR2000 because it can output sysex messages apparently. I did link  VEdit to BC Manager with MidiYoke Virtual Midi to read the sysex messages(which works!!). Then copy and paste the message into something like Bome's Midi Translator.
I'm still a novice dealing with such things as sysex, that I need to read more
Max Roland
Hi, i recently bought a vg-88 v2 and  want to   use it as a controller on sibelius and kontak ¿Does anyone use it like this?
Quote from: Max Roland on October 22, 2023, 10:10:35 PMHi, i recently bought a vg-88 v2 and  want to   use it as a controller on sibelius and kontak ¿Does anyone use it like this?
like the VG-8, the VG-88  lacks Guitar to MIDI  function
https://www.roland.com/us/support/knowledge_base/201922959/
DIFFERENCES BETWEEN GUITAR SYNTHESIZERS AND THE VG-8
Back to Results
Tags: gi-10, gr-1, vg-8, vg-88, gr-09
The VG-8 / VG-88 V-Guitar is not a guitar synthesizer like the GR-09, GR-1 or
GR-30/33, or a Guitar-to-MIDI Converter like the GI-10. In the GR-Series and
the GI-10, the signal from the GK-2A pickup (which is analogous to a standard
pickup signal for each string) is converted to a pitch which is then available
to trigger a sound, either internally (GR-09, GR-1, GR-30) or through MIDI.
This makes these units ideal for sequencing and playing realistic sounds like
pianos, organs or drums.
On the VG-8 / VG-88,GP-10 the signal from the GK-2A / GK-3 hex Pickup is modified in realtime into an
entirely new sound which allows all of your picking and playing techniques to
be preserved. The VG-8/ VG-88 does not transmit MIDI note numbers, nor does it
act as a MIDI sound module. Although the VG-8 / VG-88 has the ability to modify
the guitar sound into unique sounds (like a synthesizer would), there is
absolutely none of the tracking delay normally associated with guitar synths
because the sound of the guitar is modified in real time. The VG-8 / VG-88 is
unsurpassed in creating a multitude of authentic guitar tones which would
previously only be attainable by purchasing a truckload of different guitars,
amps and speakers.
Max Roland
so its better to buy a gr20 or gr55 to use it as a midi controller on a software? i had a line6 hd500 its better than the vg88? at least it's newer
Quote from: Max Roland on October 31, 2023, 08:06:23 PMso its better to buy a gr20 or gr55 to use it as a midi controller on a software? i had a line6 hd500 its better than the vg88? at least it's newer
What sort of midi control are you after ?
Guitar to midi notes for synth software
or
a midi foot controller for patch changes and real-time effect control ?
