roland gr 55 midi controller? ??
Started by uziel_lpz, September 18, 2015, 11:22:12 PM
uziel_lpz
 Hi I would like to know what controllers could I use to control gr 55 ive been looking into the guitar wing. Is it possible to use guitar wing to control parameters on the gr 55? In not looking for a foot pedal control. I want something I could adapt to the guitar I know there are usb midi host I could use. What are some midi controllers good for gr 55??
To use Guitar Wing as MIDI Controller for GR-55 Control Assignments , obtain a USB Host to MIDI Conversion box
* 2011 iConnectMIDI ( still available at MIDI-CLASSICS.com )
* iConnectMIDI 4 Plus
* Kenton USB HOST TO MIDI
Read comprehensive list of MIDI Controllers here
https://www.vguitarforums.com/smf/index.php?board=7.0
uziel_lpz
You are awesome and with the usb midi host I won't need the  computer right?  Have you tried this or do you know anybody that has done it. If there's a video you know send me the link please.  Thank you so much! !!!!
Quotewith the usb midi host I won't need the  computer right?
Correct - USB Host to MIDI Conversion box  means no computer required
QuoteHave you tried this or do you know anybody that has done it.
Yes it works
uziel_lpz
uziel_lpz
hi i know you already told me what midi host i could use to connect guitar wing to gr 55. while i was looking  i found the midi expander from keith mcmillen do you thing i could use this too? its a lot cheaper than the other ones. but im not sure i does the same as the others thank you
Quotei found the midi expander from keith mcmillen
Already confirmed KMI midi expander does not work with non KMI products!
