MikroElektronika - BassBay Bass MIDI Synth $29
Started by Elantric, April 12, 2017, 05:21:43 PM
MikroElektronika - BassBay mono Bass MIDI Synth $29
https://shop.mikroe.com/add-on-boards/audio-voice/bassboy?search_query=audio&results=19
https://download.mikroe.com/documents/add-on-boards/other/audio-and-voice/bassboy/bassboy-manual-v102.pdf
BassBoy
PID:  MIKROE-684
Weight: 30 g
BassBoy is a monophonic digital MIDI controlled bass synthesizer. Device receives all information via MIDI input (DIN5 connector, not included). With your own digital MIDI bass synthesizer your MIDI songs will sound like a real live stage band. BassBoy runs on 8-bit ATXMega32D4 microcontroller.
BassBoy is a monophonic digital MIDI controlled bass synthesizer. Device receives all information via MIDI input (DIN5 connector, not included). With your own digital MIDI bass synthesizer your MIDI songs will sound like a real live stage band. Powerful 16-bit DSP signal processing and hi-performance DAC ensure that you enjoy in each and every sound.
Product Type   Audio
Applications   BassBoy is a monophonic digital MIDI controlled bass synthesizer. Device receives all information via MIDI input (mono connector)
On-board modules   MIDI input (mono connector)
Key Features   Sampling frequency is 31.25KHz which generates audio range up to 15.625Khz. Although it's based on 8-bit processor, the signal processing inside the unit is 16-bit
Key Benefits   The unit is mono, and 6.35mm jack is also used as carrier for the circuit board itself
Interface   MIDI
Power Supply   5V
Compatibility   Other
