VG-99 - Any advice on how to do this (Logic x)
Started by Etolle, December 13, 2014, 08:10:56 PM
Etolle
Let's say I want to set up two guitars (Strat left and LP right). I want to send the left guitar to it's own track and the right to it's own track. I have a Focusrite Pro 14 (it's routing options are confusing to say the least). I have usb and I also have sp/dif and the Focusrite has sp/dif in and out. What I'm mainly trying to do is record just the dry modeled guitars (each on it's own seperate track) and use amp sims within Logic X because I want to be able to change the amps after recording if necessary. I know recording two takes seperately is preferable but sometimes I'd like to record stereo guitars.
Reamping using the Vg-99 via usb is also something I can't find clear info on either.
Also, If I do usb, I can record in stereo but only to one track in logic so I can't use two different amp sims (one for each guitar).
If anybody can help on this it would be awesome.
