Boss FV-50L or Boss FV-50H for VG99?
Started by Pin, December 13, 2014, 06:45:20 AM
Pin
Hi folks, I tried (as I usually do) to find an answer on search but couldn't.
Do I need low or high impedance expression pedal for the VG99 or does it make no difference? I am thinking of the Boss FV pedal. I have no plans for the FC-300 yet.
These are volume pedals, not expression pedals.
Use the high impedance one if you prefer it before FX (fed straight from your guitar jack), low after FX.
http://www.bossus.com/gear/productdetails.php?ProductId=59
Not particularly helpful in a 13 pin configuration, unless you feed a guitar out somewhere separately & want a volume pedal there.
davep2000
Impedance is a property of AC circuits due to inductive/capacitive reactance and frequency
Your choice of Boss FV pedals looks to include both in/out for guitar connection, therefore the guitar pick ups reactance
A standard guitar cable should be used, the FV50 goes in series with the guitar and amp
The EXP connection is an expression pedal output
The effects pedal will monitor a DC signal across the connection and vary your assign etc
You need to connect a stereo cable
You also need to be aware of polarity, ie heel down/ toe down position
The FV range has more options onboard
I've used a dedicated EV5 expression pedal before I bought the FC300
