Guitar output & effects
Started by JCcares, August 16, 2011, 06:10:13 PM
JCcares
I noticed that when you feed the modeled guitar to come out of the guitar out,it comes out dry.But at the same time it is heard on the main out's with effects.
Is there anyway to get the modeled tones with the effects out of the guitar out?
Is there a way to mute the modeled guitar coming out of the main out & have it heard only out of the guitar out?
Thanks.
The guitar out jack will only provide un-processed (raw) guitar, modeled or normal P.U., or Both.
No effects out of there, you must provide your own effects for guitar out.
Switch off the Modeled tone and theat will kill the modeled tone  at the main outputs, the guitar out works independant of the tone on/off switch.
JCcares
Thanks.So I think there is really no way to mute the modeled guitar coming out of the main out & have it heard only out of the guitar out.
As is said below, switch "off" the modeled tone in the GR-55 menu, and the modeled tone will still be heard only out of the guitar out jack, as it operates independantly of the on/off tone setting.
dayslypper
Hello,
please, is it possible to get pure unprocessed sound of GK pickup (or pure sound of piezo pickups of Synth Acces guitars) from any output of GR-55 without modeling?
If the "guitar out" setting is to 'normal pickup', you will get what ever signal is fed into the GK-3 guitar input (the guitar's normal builtin pickups), the raw hex pickup does not output through there, and i would imagine the hex pickup would not sound too good for direct audio.
For Synth access guitars, that depends on the internal structure, many have a summed output of the hex piezo pickups.
Quoteis it possible to get pure unprocessed sound of GK pickup (or pure sound of piezo pickups of Synth Acces guitars)
You will need a break Out box, and then feed a separate multichannel I/O Audio interface. (I use a MOTU 828 MK3)
Breakout Box
http://billbax.110mb.com/index.html
RMC Fanout Box
http://www.rmcpickup.com/fanoutbox.html
Ricky Graham Septar board Kit
http://rickygraham.com/septar-board-beta-kits-june-2011
dayslypper
#7
Thank you for answer where are some split boxes.
NOW I need to find solution for my rig.
I would like to use Analog distortion (stomp-boxes) and GR-55 only for synth + digital effects (modulation, delay, reverb).
Simply, I would like to use GR-55 in the same way as it's possible with VG-99 which has Guitar input.
Is there any useful box in the market?
Here is the chain that I need:
                           --- sound of magnetic pickups --- analog effects chain ---
Guitar --- GK cable ---<                                                               >--- GK IN in GR-55
                           -------------------- sound of 6 strings ------------------
