MIDI CLOCK GENERATOR Utility for Windows
Started by Elantric, January 06, 2017, 06:00:59 PM
http://www.voiceliveeditor.com/index.php/vle-utilities/vle-midi-clock-generator
Midi Clock Generator Utility FREE windows logo
(No Warranty is implied with this application suitability for your specific needs, you use this utility entirely at your own risk).
This utility allows you to adjust the BPM of a Device(s) that support Midi Sync/Clock as a Slave.
ie VoiceLive 3, VoiceLive 2, VoiceLive Touch 2 etc.
midi generator pic
1) Start The utility, click the Midi Icon (Top Right), select the device or devices you wish to send the Midi Sync Data to.
2) Click the Start (large Arrow) Button. The utility will now start sending the Midi Clock Data, the Red LED should start blinking when data is being sent.
You can adjust the BPM with the Dial, and also nudge up/down by one BPM with the arrows.
BBach
Seems like this would be of limited usefulness. Useful in being able to instantly getting all of your devices set to the same tempo with just one setting, but without song position info, no ability to sync devices relative to measure start. So, for instance, the SY300 will play the note sequence starting at the multiple of ppqn/tempo that happens to be occurring at the moment, not the beginning of the pattern. Without a synced reference music the musician will be in tempo with the other instruments being controlled by this software, but cannot depend on knowing where in a sequence/arpeggiator pattern he might be when he plays a note. As long as you are using a computer, you might as well use your DAW to control tempo and provide reference as to where you are in a song.
