VG-99- Difference between polyfx and fx?
Started by monks, June 09, 2014, 05:04:03 AM
monks
Title says it all...what's the difference between them?.....
monks
supernicd
Imagine having 6 compressors in your signal chain, one operating on each string, instead of one compressor that takes its input from all 6 strings mixed together.  Now imagine having 6 distortion pedals in your signal chain.
Strat w/ GK-3, Godin LGXT
VG-99, GR-55, GP-10
monks
So it potentially applies a separate fx to each string?...or it always does?
monks
supernicd
The Poly FX always apply to each string individually, though your ability to control them is not on a per-string basis.  You are given a balance control.  At least that is how they're implemented on the VG-99 - not sure if Roland/Boss has made any changes with the Poly FX on the GP-10.
It is not a distinct effect per string, though.  You can't apply distortion to one string and comp to another.
VG-99, GR-55, GP-10
http://www.soundonsound.com/sos/dec07/articles/rolandvg99.htm
There's a separate multi-effects section for each channel and a poly effects section (one effect per string) that can be used on either channel, but not both at the same time.
http://cms.rolandus.com/assets/media/pdf/VG99WS01.pdf
Polyphonic effects—or "Poly FX" allow you to apply powerful
effects processing to each string individually. Available
Poly FX include compression, distortion, octave, and Slow
Gear.
