GR-55 Training Videos
Started by Elantric, November 12, 2012, 02:01:32 PM
http://www.youtube.com/playlist?list=PL30BD4C57079D85E0&feature=plcp
QuoteGR-55 setup video from Roland for piezo equipped iGuitars and Brian Moore Custom Models. This video is produced by Peter Swiadon, guitar products manager for Roland USA. It features one or Peter's favorite guitars, an iGuitar2.13 Natural with RMC piezo (and works the same for Graphtech piezo equipped guitars)
Some of the factory Preset patches in the GR-55 have the CTL pedal and/or EXP SW assigned to control various functions, for example, the PCM Tone On/Off switch.??An assignment of this nature can make it appear that User parameters are not being stored in a patch. To turn off the pre-assigned CTL and/or EXP SW functions, follow these steps.
1. Select the desired User patch.
2. Press the EDIT button.
3. Press PAGE left or right to select the MASTER tab, and then press ENTER.
4. Cursor left to "PEDAL/GK CTL," and then press ENTER.
5. Cursor down to "CTL FUNCTION," and then turn the dial counterclockwise to select "OFF."
6. Press PAGE right to select the EXP SW tab.?
7. Cursor down to "EXP SW FUNCTION," and then turn the dial counterclockwise to select "OFF."
8. Save this new setting into the patch by pressing WRITE twice.??Note: Some patches may also contain assignments in the ASSIGN section that can effect custom stored parameters. If the above steps don't help with your patch, go to the ASSIGN menu, turn off each assignment in the patch, and then save the settings
 Training video example  GR-55 Guitar to MIDI  triggering softsynths in FruityLoops.
Roland GR-55: Assigning a MIDI Control Change message (CC#) from an FC-300
drjoness2001
Extensive Real-Time MIDI Control of the GR-55 Using the Roland GM-70 Turbo and Ibanez IMG2010. The first clip is a performance video, the second clip covers some of the modulation assignments used in the performance clip:
Serbian GR-55 Review
Added new GR-55 Setup Videos by Michael Sullivan
GR-55 Tips, Tricks & Techniques
Having trouble getting your GR-55 to behave itself? Here are some setup tips and playing techniques that might help!
Roy Smith
There are lots of videos showing the sounds on the GR-55, but I thought it might be helpful to people who are considering it if I made a video that shows how the sounds are created and edited. The GR-55 has a lot of horsepower for making amazing guitar sounds, and you can see how it's done here.
Roland GR-55 with the Brian Moore iGuitar LP with RMC Piezo
Drums
GR-55 System Settings Part 1 of 4
GK SETTINGS
In this video, Kennis Russell shows you how to set the GK SETTINGS in the GR-55. The GK SETTINGS calibrate your guitar for the GR-55. This helps eliminate ghost notes and improves the performance of the guitar. Make sure to watch all four parts in this series and please don't forget to Like, Comment, and Subscribe.
http://youtu.be/tHsAbmEXrGE?list=RDd8BikMeffjA
GR-55 System Settings Part 2 of 4
OUTPUT SELECT
In this video, Kennis Russell shows you how to select the OUTPUT in the GR-55. The OUTPUT SELECT settings tell the GR-55 what kind of amp or PA you are playing through. The GR-55 then adjusts the output accordingly. So weather you are playing through a tube amp, solid state amp, PA, or more, the GR-55 gives you the best sound for your setup. Make sure to watch all four parts in this series
GR-55 System Settings Part 3 of 4
PEDAL / GK CTL
In this video, Kennis Russell shows you how to set the PEDAL / GK CTL SETTINGS in the GR-55. The PEDAL / GK CTL settings allow you to set the controls of the GR-55 to your taste. Weather its the Expression Pedal, CTL Button or the contols on your GK-3, you can set them to function just the way you want. Make sure to watch all four parts in this series
GR-55 System Settings Part 4 of 4
OTHER SETTINGS
In this video, Kennis Russell shows you how to set the OTHER SETTINGS in the GR-55. The OTHER SETTINGS are settings that allow you to fine tune the controls of each patch even further to function just the way you want. Make sure to watch all four parts in this series
A how to edit and create patches tutorial of the Roland GR-55 Guitar Synthesize. This is part 1 in a 4 part tutorial. Part 1 focuses on editing the PCM sounds, Part 2 focuses on the Model guitar effects and Part 3 focuses on Normal Pickup, overall effects and part 4 is final edits and playing the sounds together.
A how to edit and create patches tutorial of the Roland GR-55 Guitar Synthesize. This is part 2 in a 4 part tutorial. Part 1 focuses on editing the PCM sounds, Part 2 focuses on the Model guitar effects and Part 3 focuses on Normal Pickup, overall effects and part 4 is final edits and playing the sounds together.
A how to edit and create patches tutorial of the Roland GR-55 Guitar Synthesize. This is part 3 in a 4 part tutorial. Part 1 focuses on editing the PCM sounds, Part 2 focuses on the Model guitar effects and Part 3 focuses on Normal Pickup, overall effects and part 4 is final edits and playing the sounds together.
A how to edit and create patches tutorial of the Roland GR-55 Guitar Synthesize. This is part 4 in a 4 part tutorial. Part 1 focuses on editing the PCM sounds, Part 2 focuses on the Model guitar effects and Part 3 focuses on Normal Pickup, overall effects and part 4 is final edits and playing the sounds together.
A how-to video on setting up the Roland GK-3 with a Roland-GR-55.
How to setup the CTL pedal to become a solo boost switch on the Roland GR-55.
GR-55 Training Videos - In Portuguese (Brazil)
http://monstrinhosonoro.blogspot.com/2011/09/primeiro-post.html
Meu blog sobre a GR-55:
Link para a postagem no blog:
http://goo.gl/ebD9yU
Eae!
Em meio ao barulho da chuva, dos cães latindo e das aves (além de meu fluente inglês do Ensino Médio da Rede Publica de Ensino, haha!), eis aqui mais um vídeo-tutorial!
Dessa vez me foquei na utilização dos ASSIGN's para um patch "de guitarras". Também aproveitei para uma leve introdução em relação aos parâmetros de utilizaçã.
Vale lembrar aqui que expus meus pontos de vista e idéias. O que procuro é apenas colaborar com os usuários da GR-55, OK?! Sintam-se a vontade para discordar e/ou criticar! Sintam-se também a vontade para opinar!
É a primeira vez que faço um vídeo relativamente grande! Logo, não revisei o mesmo, considerando que fui criando e tal... até o que esqueci ou errei (programação e dicção, algumas confusões no meio) continuaram - além do fato de criar/gravar/editar sozinho.. - mas nada que interfira no propósito do vídeo!
P'ra variar, a câmera do telefone (com a minha imagem) foi atrasando, mas o áudio condiz com o visor da pedaleira.
Por fim é isso! Espero que seja de ajuda para os users!
Os links:
TUTORIAL - Alterando Settings do GK na GR-55:
http://goo.gl/o4Khln
PATCH - 2GTR GIG:
http://goo.gl/8hHEVp
Ah, e para uma melhor visualização, procure deixar o player do Youtube com uma melhor qualidade! Para diminuir de tamanho, converti o vídeo, e ainda tem a questão da qualidade das câmeras utilizadas (fotográfica e celular).
É isso!
plexified
#12
 Yeah,
          Roy is "Groovatine" or known here as 'The Grail'. Well earned master class status as everything Roy has done is remarkable. From jams with friends to hosting huge festivals, Roy is off the charts.
https://www.youtube.com/user/logabass
