RCF M Series Digital Mixers with Guitar FX and remote pedal+ iPad Control
Started by Elantric, May 06, 2016, 08:18:08 PM
http://mixer.rcf.it/rcf-m-series.html
http://www.rcf.it/c/document_library/get_file?uuid=34679801-79bf-4165-961e-9ed413f15ce1&groupId=216492
CF Announces Firmware Update and Unveils Expansion To RCF M Series Mixers
April 19 2016, 03:04
Following their successful launch in 2015, RCF's M 08 and M 18 digital mixers will now enjoy enhanced functionality thanks to the latest firmware update. At the same time RCF has hinted that the wireless-controlled digital mixer series will shortly extend, with a larger-format M 24, 24-input chassis, for larger production duties.
RCF Announces Firmware Update and Unveils Expansion To RCF M Series Mixers
Umberto Zanghieri discusses the new RCF M Series updates with audioXpress editor-in-chief João Martins, during Prolight+Sound 2016.
In 2015, RCF introduced the M Series 8http://audioxpress.com/article/RCF-launches-TM18-Digital-Mixer-and-Expands-L-PAD-Mixer-Range.html), a new generation of small-format digital audio mixers designed for the performing musician. The result of an intense development effort by the new  RCF Digital Audio Division, headed by engineer Umberto Zanghieri and its dedicated team, the M 08 and M 18 wireless controlled mixers are showing the way for the future of the technology, creating an affordable but extremely complete solution which was not previously available to the market. While many of the functionalities of RCF's new M Series mixers existed previously in more sophisticated (and much more expensive) live sound mixers for Front of house and monitor duties, the M Mixers represent a fully integrated solution for musicians, fixed-installations and event applications.
Maximum flexibility and comfort are granted by internal power supply, integrated Wi-Fi access point and antennas, while the complementary MixRemote App enables complete and versatile control of the RCF M series digital mixers.
All M Series mixers combine a full set of connections, from XLR and combo connectors for musical instruments, uncolored mic preamp inputs, and a complete range of line inputs, some of which switchable to Hi-Z – High Impedance – for acoustic or electric or bass guitars with passive pickups. The remote-controlled Mic Gain allows the user to control the Mic Preamps and Line input Gain even at high distance from the mixer. All the settings are stored in the snapshot memories and can be recalled according to the user's needs.
Balanced AUX outputs are also on hand to connect stage monitors or external effect processors, in case the mixer's internal processing is not sufficient for the user's needs. The +22 dB balanced MAIN MIX outputs are supported by a pair of male XLR and a headphones stereo output completes the series design. Using the Personal Mix function on the Phones menu of the MixRemote App it is possible to create a fully personalized stereo monitoring. The headphones' output also offers Main Mix and, alternatively, PFL listening.
MIDI IN and OUT ports are also present on the rear panel, allowing the connection of various types of MIDI controllers. At Prolight+Sound 2016, RCF launched the MR5 dedicated MIDI footswitch, which enables users to recall effects' presets or to mute effects' returns, as well as providing several other control functions.
A USB type-A port allows connection of USB devices, such as pen drives or hard disks, to create a complete stereo system for playback and audio recording: this supports all the most common audio file formats, both high-quality and compressed. The intuitive graphics of MixRemote App helps the user to manage song playlists also with the AUTO play function.
Wile the current models are targeted firmly at performing musicians, RCF has already unveiled a larger model which will be able to respond also to larger setups and fully address the needs of any small-sized live event, including recording and virtual sound-check. During the Frankfurt show, RCF unveiled the M 24 model, with 16 mic preamps and 8 line inputs, 4 internal send FX, 6 assignable MultiFX and an integrated USB audio interface with 32x8 channels. RCF also displayed the S24 configuration with an expanded 8 balanced Mix Out channels. The existing models, M 18 and M 08, have eight and four mic preamps respectively, boast high quality reverbs and share the same algorithms. The larger models have three internal FX Sends (Stereo Reverb, Stereo Delay and Assignable), while the M 08 has two (Stereo Reverb and Assignable).
Firmware Upgrade
With the firmware upgrade for the M 18 and M 08 mixers, several new features have been included to address the requirements of modern musicians and bands. The new firmware upgrade was previewed for the first time at Frankfurt Prolight+Sound 2016 and includes several improvements and additional processing effects. Enhancements will include novel amplifier modeling simulations, licensed from Overloud, bringing the total number of models to 15, and four additional Stomp Box style effects; The stereo file player will be expanded to allow four-channel playback, representing one of the few compact mixing solutions with multichannel playback on the market.
Explaining the rationale behind the player upgrade, Umberto Zanghieri, Director of RCF Digital Audio Division, stated, "I wanted the musicians to have the backing track in stereo along with a click track which they can route on their headphones."
Improved preamp section with Overange, Heavy 51, and Slo88 presets and additional Stomp Box effects: Acoustic Simulator, AutoWah and Ring Modulator.
RCF is also enabling LAN network bridging on the new firmware, making it possible to navigate the web on the same tablet being used for mixer control. Another welcome addition on the new firmware will be the presence of 4 DCA Groups, which will allow the grouping of input channels with a single level and mute control.
Finally, RCF demonstrated an Android version of the dedicated MixRemote App, with similar functionality as the iOS version, fully accessible from a tablet and covering all existing functions. The new firmware will be downloadable from the RCF website and will be free of charge. The current MixRemote app is available from iTunes store.
Summing up, Umberto Zanghieri states, "These models now have one of the most comprehensive feature sets in their class. It's the only series on the market of compact digital mixers that has dual amp modeling, licensed from Overloud and Markbass, 4-track file playback from USB drives, internal WiFi Access Point and various audio effects".
www.rcf.it
http://www.rcf.it/en_US/m-digital-mixers/m-18
M Mixers represent a fully integrated solution for musicians. Maximum flexibility and comfort are granted by internal power supply, integrated Wi-Fi access point and antennas: the only thing musicians need to carry are their instruments. Avoid transporting heavy and bulky cabinets, thanks to the internal amp modeling simulators, expressly conceived for guitarists and bass players.
http://www.audioxpress.com/news/RCF-Announces-Firmware-Update-and-Unveils-Expansion-To-RCF-M-Series-Mixers
https://itunes.apple.com/us/app/mixremote/id1053268034?mt=8
RCF MixRemote for iPad
Description
The MixRemote app for iPad allows full remote control of the M series of digital audio mixers, through their internal WiFi Access Point. The M series digital mixers are compact, self-contained, feature-packed faderless units which are ideal in all cases where live music is being performed. Several internal digital effects, both in send and in insert, are available for maximum flexibility.
Several iPads can connect to the internal WiFi Access Point and manage all the available parameters. No audio is transferred between the iPad and the digital mixer, and all features of the digital mixers are accessible with this app, without requiring an additional computer for specific settings.
Features:
- Intuitive user interface and consistent layout
- Complete recall of all parameters (SHOW)
- Song-oriented recall of a parameter subset (SNAPSHOT)
- Several multi-effects on specific inputs, whose parameters can be saved and recalled as a PATCH
- MFX1 and MFX2: 3 effects in series (modulation, delay, special FX)
- MFX3 and MFX4: 5 effects in series (overdrive, modulation, delay, special FX, amp simulation)
- Other 3 effects with dedicated send (post-fader) busses
- on all physical inputs: a versatile Noise Gate, a flexible and musical Compressor with two available modes: Easy (one-knob) and Advanced
- 4-band Parametric EQ on each input, with three selectable modes: Standard, Vintage and Mmooth
- 4-band Parametric EQ (in standard mode) on AUX and PHONES outputs
- Presets are available for Noise Gate, Compressor, EQ, Reverb, and other effects on send busses
- 31-band Stereo Graphic EQ on MAIN left and right outputs, with presets
- Microphone Preamps with digital remote control, switchable 48V phantom power and phase invert
- Line inputs with selectable -10 dBV / +4 dBu sensitivity; two line inputs can be switched into Hi-Z impedance mode
- Two simultaneous amp simulations of guitar and bass amplifiers, licensed from OverloudTM
- Modeling of MarkBassTM TTE-500 and Little Mark III amplifiers
- All inputs can be linked into stereo pairs
- Dual footswitch with assignable functions: individual FX on/off on MFX1, MFX2, MFX3 and MFX4, previous and next MFX1/MFX2/MFX3/MFX4 PATCH, previous and next SNAPSHOT, player control
- Flexible stereo file player, with selectable Auto mode that enables automatic playback of next file
- Supported file types on the player : WAV16, WAV24, AIFF, MP3
- Internal stereo RECORDER on USB flash drive, with dedicated trim and VU meter
- MIDI control of several parameters
- 5-pin MIDI and USB-MIDI support (automatically merged)
- Selectable internal/external WiFi second antenna; the first antenna is internal (M18 only)
- Separate buss can be selected for PFL solo or Personal Monitoring (independent stereo mix of all inputs)
- Mastering Processor on MAIN left and right outputs, including Valve Warmer, Xciter and Maximizer processors; the three units can be configured from a single preset for maximum ease of parameter recall
- Several iPads can be connected at once (up to 5) to enable simultaneous control from different performers
- A LAN port is available for connecting an external WiFi client or Access Point
RCF spa Web SiteMixRemote Support
What's New in Version 1.1.0
This release is compatible with previous firmware builds, but to take advantage of all features, we strongly recommend to upgrade your M18 unit to the latest firmware (build 203 or higher).
What is new in version 1.1:
* Several improvements for faster interaction
* RECORD page is enabled (it requires firmware build 203 or higher)
* improved MFX selection indicator: ON/OFF state of effects is now shown explicitly
* PFL level is now visible on MAIN VU meters
* one-knob operation for preamp GAIN
* corrected MIDI implementation
* IP address selection at connect
* Tap tempo option on SEND delay effects
* several bug fixes
http://www.soundonsound.com/sos/jun16/articles/rcf-m18.htm
Quotepros
Straightforward GUI with excellent graphics.
Wi-Fi built in.
Strong audio performance with very capable effects that include guitar and bass amp modelling.
Remote preamp gain control on all mic inputs and the two amp modelling channels.
Effects can be bypassed via footswitch.
cons
Tablet control for iPads only at the time of writing.
No global effects bypass in the app.
No gain-reduction metering on compressors or gates.
No delay tap tempo.
summary
A flexible and very practical self-op mixer for anyone who wants to DI as much as possible and to control their show from an iPad.
https://youtu.be/zdvVzjdNSH0?list=PLRJewhnJCvuljpqJsHf-djYtr97oVRQqb
Tutorials
! No longer available
https://fccid.io/2AHDK-M18DIGI/User-Manual/Manual-3622641
https://www.rcf.it/products/mixing-consoles/m-series/m-18-firmware-update
READ THIS FIRST
You may need to perform a two-step firmware update, depending on firmware version currently installed on your M18 unit. If you current firmware version is 187 or earlier, please update to version 221 first. Then, after power cycling the unit, you can perform the desired firmware update to version 226. Here is a summary of required actions, depending on your current firmware version:
177 ->update to 221 first -> update to 226
182 -> update to 221 first -> update to 226
203 -> update to 226
221 -> update to 226
222 -> update to 226
We strongly advise NOT to perform a firmware downgrade (that is, with a version which is earlier than the one you currently have on your system). Therefore, do not perform an update to 221 if you already have 222 or 226.
https://www.rcf.it/en_US/products/mixing-consoles/m-series/m-18-faq
https://www.rcf.it/en_US/products/mixing-consoles/m-series/m-18-firmware-update
CHANGE LOG ver.230
A maintenance M18 firmware release is available.
NEW FEATURES:
Metronome configurations are now saved into Snapshots
Due to FAT32 limitations, recording was stopping after 2 hour of continuous recording. This limitation has been removed; now multiple files are generated after each 2 hour limit, to ensure gapless recording. The complete registration can be reconstructed on a DAW.
Pre/Post setting of AUX5/6 fader sends are now correctly recalled with SHOWs
App requirements to unlock all features:
MixRemote for iOS, version 2.0.3.166 or later
MixUpdate for iOS, version 1.2.0.34 or later
MyRemote for iOS, version 1.0.0.108 or later
MixRemote for Android, version 2.2.1.55 or later
MixUpdate for Android, version 1.2.0.120 or later
MyRemote for Android, version 1.0.0.10 or later
The new M18 firmware is fully compatible with previous app versions, although some of the latest features may not be available.
Quote18 analog input channels, 8 mic preamps and 10 Line inputs including 2 HiZ switchable inputs
Three internal FX: Reverb, Delay, Modulation
19 simultaneous studio-grade effects, including Guitar & Bass emulations developed by Overloud
MixRemote app ensuring a comprehensive control
Valve warmer, Xciter, Maximizer and Stereo Graphic EQ on Main Mix
1 stereo main out and 6 aux outputs
USB port for the internal four-track player and two-track recorder
1 dual footswitch connector
Internal power supply
