gk3 volume not working
Started by terry123, May 27, 2015, 02:05:14 PM
terry123
Only had the GR55 a few weeks but love it already, one problem I have is that the GK3 volume control doesn't always work if I do a factory reset it works but when I restore my patches it does nothing, the volume stays at about half way regardless of where the control is set.
Please is there anyone out there that has had this problem and got it sorted. Cheers :P
Upload one of your problem patches where GK Vol is stuck midway up.
Others here can debug your corrupted Control Assignments
Which process are you using to restore your patches?
If you are using the USB memory stick with the GR-55's internal backup process, then it will backup/restore all user patches (guitar & bass modes) and 'all global/system' settings.
If you have a bad system setting, then you will be restoring the same problem setting.
I recommend using either the Roland Librarian or GR-55FloorBoard software to backup the patches only, then do the factory reset, then restore only the patches, and dial in your system & GK settings from scratch.
