GK2A pickup on GK3 kit board
Started by sec6, November 15, 2015, 09:55:38 AM
sec6
Just a question about installing a GK2A pickup onto a GK3 kit: is it possible to connect a GK2A pickup directly to a GK3 board?  Are the connectors the same?
Depends on the year of the GK-2A
Roland changed the 8 pin connector from a 2mm pitch to a 1.5mm pitch  - but electrically they are wired with the same string sequence, ground, and shield connections
its rather apparent as the size of the connector is quite different
sec6, I stock all these components (1.5 & 2.0 pitch)...PM me if you get stuck.
Cheers, Peter in Oz
Good stuff Steve..unnerstood..
PM if the situation changes...or you need to visit!   ;)
Peter
