GR-55 - Need an emerson/wakeman/magic man minimoog patch
Started by mdortona, June 06, 2014, 10:32:19 AM
mdortona
Anyone have anything close? Band is going to be doing Magic Man, and possibly From The Beginning. Thanks!
Matt
P.S. Sorry for the double post. I mistakenly posted in the child boards first. :o
DreamTheory
I am just learning to do this stuff. Preliminary answer: a square wave form with the cutoff filter sweepable on foot pedal. Slightly slow attack, portamento. CTL for LFO to cut on tremolo at end of that solo. Duplicate to PCM tone 2 a detune the second one (fine setting -5). I will repost something more specific when I get a chance, but since this is an "emergency," that should get you something for now.
papabuss
mdortona
Thank you guys for the detailed info and the patch! Should do the trick for me.  ;D
Matt
DreamTheory
Well I took a crack at the Magic Man patch creation, And came up with this, which is pretty much what I described above. The pedal will sweep the filter and drop you down an octave, and the CTL will pop on some crazy vibrato for the end of the solo.
This was tricky because there is a lot going on in that syth solo. What makes GR 55 interesting is that you have more than one way of doing things, but there are limited numbers of controls, so you have to be strategic how you want to build the patch.
My patch won't be as good as Papabuss' because I am pretty new at analog synthesis. Most useful thing I have found is detuning the second PCM voice a little on the FINE detune parameter. Good luck with your gig, and thanks for the stimulating challenge.
mdortona
concordal
songbirdwhosings, many thanks for posting your patch for ELP.  It has a .mid suffix as opposed to a g5l suffix.  Is that because it's a VG-99 patch?
DreamTheory
#7
No it's because I did the procedure wrong. Sorry- that was my first patch exportation. Here it is with the proper format.
Also an MP3 with a little sample of how it sounds
DreamTheory
Quote from: papabuss on June 07, 2014, 10:36:47 AM
Matt, I made a patch for ELP's Lucky Man here some time ago
https://www.vguitarforums.com/smf/index.php?topic=6059.msg41690#msg41690
I have had the strangest trouble trying to load this. I get the correct patch name, and the CTL changes the sounds from Model to PCM, and the EXP pedal does the pitch bend, but the tones are just Strat and Piano, the default "initialize" tones. I have tried to upload it from your original messsage and the forum. I can get other patches from the same list and most are OK, but some other patches do the same thing- give the name and control settings but not the correct tones. Any idea what is going on or what I can do?
QuoteI have had the strangest trouble trying to load this. I g
Are you using Gumtown's GR-55 Floorboard Editor?
https://www.vguitarforums.com/smf/index.php?topic=2951.0
DreamTheory
No, I am using the GR 55 Librarian. Is it that buggy?
90% of us here are using Gumtown's GR-55 Floorboard Editor to create and manage the GR-55 patches posted here.
Suggest use it.
And read
GR-55 FAQ: TOP THINGS TO KNOW
DreamTheory
#12
make that 91% (if you get advice from Elantric, I say follow it) ... I'm off to gumtown....
