VG-99- Digital Output
Started by ericar123, February 18, 2016, 07:23:09 AM
ericar123
Hi
Does anyone use the Digital output(RCA jack) on the VG99?
I have an M-Audio card that has an S/PDIF RCA jack on it.
Will this work and give me better quality sound into my computer?
Is there anything involved with setup other than connection?
I did try this years ago and couldn't get any sound.
Thanks for any help
ericar123
Thanks,
I did a search on digital output and didn't find much.
The spdif search did.
Quote from: ericar123 on February 18, 2016, 07:23:09 AM
Hi
Thanks for any help
It should give the same sound quality as the USB audio depending on your sound cards specs ,
better than the analoge inputs for sure.
szilard
Hi
I use it occasionally. Normally I go thru a D/A converter. There are a couple things to setup like the other outputs - source (COSM GTR A/B, PU, CH A/B, Mixer, ...) and level.
scratch17
There is a minor issue with the SPDIF output in my studio. The VG-99 sample rate is 44.1 khz. I run most of my projects at 96 khz so the VG-99 sample rate conversion is not an even multiple of the project. So I currently use the analog outputs.
I could use a sample rate of 88.2 khz. My UAD Apollo interfaces can accept a 44.1 rate and revlock it to 88.2.
At some point I want to get a Mutec MC-4. It can convert SPDIF to ADAT or AES/EBu from any standard sample rate to any higher one. My Kemper also has the same issue.
VG-99, FC-300, RMC Fanout
RJM Mastermind GT10
Kemper Profiling Amp
Radial JDV Mk3, X-Amp
Mesa Recto Pre + 20/20
68 Fender Bandmaster (AB763)
Marshal AS80R
ericar123
I've never had good luck trying the USB input. It has never worked right for me.
I use USB for the editor only.
