VG-99 - RX PC MAP?
Started by rockhound, March 09, 2011, 08:14:32 AM
rockhound
Can anyone explain what the RX PC MAP actually does and how to set it up to use with the VG-99. I have tried sending or receiving with this thru the VG-99 and can't seem to get it to respond. And yes both are set to same midi channel with VG set to PC out?
Thanks.
On the VG-99 you will have to turn it on as follows.
FIX
The VG-99 switches to the patches predetermined
for the corresponding received Program Change
messages, regardless of the Receive Program
Change Map settings.
PROG
The VG-99 switches to the patches set in the Receive
Program Change Map.
Then you will have to set the MAP up with something other than 1=1 for example 1=35 then send PC 1 and it should switch to 35.
You can also setup the Transmit Map the same way as follows.
FIX
Regardless of the patch settings, Program
Change messages predetermined for each
patch number are output.
PROG
The Program Change messages programmed
in each patch are output.
