BUZZ-OFF® Fret Leveling Kit by John Bogdanovich
Started by Elantric, November 18, 2014, 10:56:49 AM
I've been looking for a Fret Polishing Block for a while - and this kit  seems adequate.
I have on of these arriving soon and I'll review
http://www.jsbguitars.com/guitar-making-products/fret-leveling-kit
BUZZ-OFF® Fret Leveling Kits now Available for Electric Guitars and Ukuleles
A fret leveling kit designed for electric guitars with up to 24 frets has been added as well as a kit specifically for ukuleles.
Buzz-Off™ Fret Kit for Electric, Acoustic & Classical Guitars - $;19.99 - Click Here to Purchase...
http://www.jsbguitars.com/productDetails.cfm?product=120
Buzz-Off™ Fret Kit for Acoustic & Classical Guitars - $18.99 - Click Here to Purchase...
http://www.jsbguitars.com/productDetails.cfm?product=36
Buzz-Off™ Fret Kit for Ukuleles - $17.99 - Click Here to Purchase...
http://www.jsbguitars.com/productDetails.cfm?product=121
Learn more about fret buzz...
http://www.jsbguitars.com/guitar-making-methods/understanding-fret-buzz
Eliminate Fret Buzz caused by High Frets
Got fret buzz? Fret buzz is a problem for guitarists. Everyone would agree that guitar fret buzz is annoying. This condition can have many causes but the most common is a high fret. A fret need only be a couple of thousandths of an inch high to cause a buzz in an otherwise properly set up instrument. Now anyone - even guitar players can fix fret buzz Level, crown and dress fret without files and without scratches!
See a Review In Guitar World Magazine...
http://www.guitarworld.com/gear-review-bogdanovich-guitars-buzz-fret-leveling-kit
Watch the video below for a fret leveling kit demonstration.
BUZZ-OFF® Fret Leveling Kit in Action
Purchase Buzz-Off Fret Leveling kit
BUZZ-OFF™ Fret Leveling Kit Ships First Class for Savings!
BUZZ-OFF™ Fret Leveling Kit Testimonials
..."everything worked just like you say in your videos. Well worth the money. Guitar plays great and rings true! Nice to hear the fretted notes and chords ring like they are supposed to. Thank you for putting out a great product !!"
-David Laudman, Bellmore, NY
..."just wanted to let you know that I purchased your fret leveling kit and I must say it is very nice... this kit will make fret-leveling a whole lot easier and more efficient. Thanks for the excellent tool and for being inexpensive!!"
-Kevin Jones, Kingsport, TN
..."Just wanted to say many thanks for the fret leveling kit. It's amazing how small tolerances and discrepancies in fret height show up easily with the system of yours. I leveled the frets on a guitar I never really cared for but now I love it! !!"
-Brian Scott, Sanford, Fl
..."I hope you make a million bucks selling those kits! They're great. With a little time and effort I've done all 5 of my guitars and they play like instruments that cost a lot more !!"
-Chris Wiliams, Raliegh, NC
..." I was able to adjust the action to the lowest I have ever seen and still have no fret buzz at all. The playability of my guitar is just fantastic! I just can't seem to put this guitar down. What a huge difference this work on the frets has made. I wanted to let you know that I think the kit you are selling is great. I'm a diehard do-it-your-selfer.
Once I saw your You Tube video, I thought this is the way to go. The price is extremely affordable, the service was outstanding with very quick delivery, and the ease of use is unbeatable. Your choice of papers is perfect - just aggressive enough with the coarse paper to work quickly, but with little chance of overdoing it. Then the fine paper smooths the fret and the steel wool polished my frets so well that you would never know I had worked on them.
Thanks for offering such a great kit at a price that is so much lower than the tools offer by the "usuals". And theirs look so much harder to use. You certainly have one very satisfied customer here.
-Mark Castelletti, Willougby, OH
How to Modify the Sanding Block for any Fret Wire
1:30
Guitar Making DVD
BUZZ-OFF® Fret Leveling Kit Sanding Block Easily Modified for Fret Size
The above video demonstrates how easy it is to modify the hardwood sanding block in the Buzz-Off® Fret Leveling Kit to fit your fret wire. Just place the 200 grit sandpaper rough side up on you fingerboard covering the fret. Rub the block over the fret with the sandpaper over it until the concave groove on the block matches your fret wire. If the depth of the groove on the bottom of the sanding block becomes too deep just sand off some material from the bottom edge of the block until you can sand the fret without touching the fingerboard surface and you are ready to go!
Origins of the Fret Leveling Kit
The BUZZ-OFF® Fret Leveling Kit was originally developed by luthier John Bogdanovich to level and set up his guitars. The necks were already flat and the dowels were used to find the high frets, and the sanding block used to crown and dress the frets. Resulting with frets all in the same plane for optimal set up. If your neck is twisted or warped in any way this kit will not be the answer to your problems, as a more involved repair is in order. But if the problem is one or more of your frets are higher than they should be, this kit will find, level, and dress any high frets in no time, a simple fret buzz fix.
Fret Leveling Kit Contents
The BUZZ-OFF® fret leveling kit is popular with guitar players as well as guitar makers. Its easy to use and everything is included, you don't have to be a guitar maker or a repair person to get the job done, anyone can do it. The kit includes a 3" and 2" steel dowel with a flatness tolerance of .001" to check frets for high spots, a hardwood sanding block shaped to properly crown frets, a piece of 220 and 400 grit sandpaper, some #0000 steel wool and instructions.
Home Depot sells the 3M Blue "Painter's Tape"
More Luthier Tools here:
http://www.jsbguitars.com/guitar-making-products/luthier-tools
