VG-99 - patch with where everything is "0", flat or balanced.
Started by ajvdn, April 10, 2008, 02:55:45 PM
ajvdn
This is a patch with where everything is "0", flat or balanced.
Regards,
AJ
ajvdn
Just some notes,
I wanted to creat a basic patch, a patch to start from. This patch is actualy a patch to create that basic patch from.
Even if you don't use the effects, the foot volume still has effect.
regards,
AJ
baranger1
Thanks for posting that Advjn.
That is the patch of gold in my eyes!!!!
Bill
Canis Testicastor
OK, I  used your patch, I enabled a COSM guitar and amp gave them settings add some patch level     and had no output? (when I I use (init) the same plan works.
What else do I need to do to get an output?
can you list the minimum steps to get a signal , pretty please with baby lambs jumping up and down.
ajvdn
Oke here we go.
Switch on the channel(s) that you are going to use
Dial in the level of that channel
Dial in the patch level
Switch on the COSM(s) that you are going to use
Dial in the volume of that COSM
Then, even if you don't use any effects open the effect chain and dial in the level of the "Foot volume"
Regards,
AJ
