VG-99 - Pulse on Freeze
Started by Elantric, February 20, 2008, 01:21:56 PM
AlexBird Wrote
Thanx for response!
The basic point in creating all of those sounds is using freeze and filter (LPF, mainly) feature of VG-99.
Here is the one patch for example. Don't be under a delusion   Wink  - its not sounds like something special if you play it in familiar way.
small example:
1. Take the note, chord or anything on guitar.
2. Move your hand or guitar neck down to the D-Beam Controller (set on T-Arm)...
3. ..and quickly turn on Freeze! ( push  CTL2 button).
4. On ribbon controller you can tweak with LPF and with F6 - reso.
Then more quickly you make step 2-3 then more strange sound may be born.
I dont explore how this trick could be useful in normal playing (not just freezed sounds)... If someone do, please let me know!
P.S. Sorry for my english:)
TygermanGB
Thanks! I like the patch. I'm uploading a version of it that has a useful addition: the slicers are tied to BPM and the 2nd expression pedal set to control the BPM. You can adjust the modulation rate even in freeze with the pedal. I really like the freeze on the ctl button.
Cheers,
-Ty
Parker Guitars - VG-99, VG-8ex, GR-55, GP-10, US-20 and Bidule/Mobious/Jamstix NI for soft synths
