EV-5 Expression pedal with a switch like on a FC-300 ?
Started by fokof, January 13, 2010, 03:09:46 PM
fokof
Is there such a thing as a EV-5 with a switch like on a FC-300 ?
Curious , before I try to "mod" mine .... ;D
I have not seen one when I did a search a while back. That does not mean there is not one though.
Look here:
https://www.vguitarforums.com/smf/index.php?topic=33.msg129060#msg129060
QuoteFor those of you looking for a physically small sized control/expression option:  I just purchased the
Hotone Soul Press Volume/Wah/Control pedal.
http://www.hotoneaudio.com/products/press/Volume_Expression_Wah_Wah_Pedal/75.html
I can report that it seems to have a 10K pot in it and works very well as a EV-5 Expression pedal substitute connected to the External Expression Control Input jack of the VG-99.
This pedal features a very compact size, metal construction, and feels generally very sturdy.
It has 3 modes:  Volume, Wah, and Expression.  In Volume and Wah mode the unit requires power. In Expression mode you can connect a TRS cable to the input side of the pedal and the unit functions as a control pedal.
Since it has a Wah function, it has a switch at the Toe position.  If you engage this switch while in the Expression mode, the expression signal goes to 0.  I've easily set up the VG-99 to turn on/off the Wah using that switch....
And, you can use it as a wah or standard volume pedal when not using it as a control pedal.
Recommended.
