GR-55 Bass -Bass VST sounds too low
Started by mcordobass, April 06, 2014, 10:01:56 AM
mcordobass
Hi :
i want to use the gr 55 with VST plugins like massive etc, I play 6 strings bass and i want to sound 1 octave higher like C4 instead of C3 .where can i do this in the gr 55 parameters?
thanks
mc
In the Master/GK settings under Alternate Tunings (when using the model tones).
I think he's looking at the MIDI output, feeding a VSTi, not COSM.
I don't think there's a way to transpose MIDI an octave via a GR-55 setting on the MIDI OUT.  I'm pretty sure you need to find a way to do that on the synth side.
Since GR-55 firmware 1.50  , as Gumtown wrote above, the GR-55 MIDI out can be transposed in the Master/GK  settings area.
