diy foot external
Started by looper, June 10, 2014, 05:32:37 PM
looper
As I said in another thread, I use the RC-300 with GR-55.
I know that the traditional method of using outside foot is with a fs-6 or similar.
But I want to create a more compact system for 4 buttons to activate commands ctrl (1, 2, 3 and 4).
Is there any problem to use starters, directly in stereo plug10?
my idea:
Ronaldo,
I understand you are in Brazil
The large Automotive switch you list may work - but it also might exhibit a phenomena called "Switch bounce"  that might prove to exhibit non repeatable behaviour in the Roland circuits when substituted for the Roland FS-6 Dual foot switch,- might work if you wire a 0.1 microfarad (100 nanofarad) capacitor
http://www.justradios.com/uFnFpF.html
in parallel across the momentary switch's two electrical connectors on rear of switch  - the capacitor helps "tame"  the mechanical switch bounce chatter typical of large mechanical switches.
But I recommend you order here your Momentary Normally Open Switches here:
Digikey Brasil
http://br.digikey.com/
Brasil | 001-218-681-7979
http://www.digikey.com/product-search/en?x=18&y=20&lang=en&site=us&KeyWords=GH1368-ND
looper
Master Elantric, thank you!
I'll see if I can find it here.
