FTP - Is it possible to access a GP-10 with a TriplePlay receiver?
Started by frummox, September 16, 2017, 10:00:52 AM
frummox
Has anyone tried this, would it work? Fishman TriplePlay Receiver > USB In Kenton Box > 5 pin MIDI cable OUT  > MIDI In MIDX-10 USB MIDI Host > USB cable out of MIDX-10 USB MIDI Host  >  USB In Boss GP-10
Would this allow me to play the TriplePlay wireless through the GP-10?
Many folks assume (incorrectly) these units employ internal "Guitar to MIDI" and trigger guitar sounds
There is nothing to "play" via MIDI Note on/off messages on the GP-10
Likewise There is nothing to "play" via MIDI Note on/off messages on VG-8, VG-88, VG-99
Why?
because the Strings are the oscillators on these units
details
https://www.vguitarforums.com/smf/index.php?topic=14088.0
CodeSmart
You need an old GR-33, SD-50 or an iPad with Sampletank etc...
Quote from: CodeSmart on September 16, 2017, 03:46:29 PM
Or plug FTP receiver directly into one of these :
https://www.vguitarforums.com/smf/index.php?topic=18939.msg135233#msg135233
Use the FC-1's  5 pin MIDI Out to trigger a third party MIDI Tone Module or keyboard synth
Some locate a used Roland GR-33 for this task (but avoid the Roland GR-55 since its PCM Synth engine does not respond to MIDI Notes on / off data)
A list of MIDI Tone Modules for MIDI Guitarists  is here:
https://www.vguitarforums.com/smf/index.php?topic=915.0
https://www.vguitarforums.com/smf/index.php?board=50.0
And a list of FTP compatible MIDI Tone Modules  w/  USB Type A Host port that allow the Tripleplay USB Receiver to directly connect "Plug & Play".
M-Audio Accent Tone Module with USB Host port (FTP)
https://www.vguitarforums.com/smf/index.php?topic=17756.msg130684#msg130684
MidiPlus Mini Engine / Miditech PianoBox Mini - General MIDI Synth Module
https://www.vguitarforums.com/smf/index.php?topic=17369.msg124001#msg124001
Myself - 90% of the time I use Tripleplay with an iPad or iPhone + Apple USB Camera Adapter
as explained in the
FTP FAQ
https://www.vguitarforums.com/smf/index.php?topic=8427.0
all sounds made using triple play and IK Sample tank on iPad Mini
GuitarBuilder
GuitarBuilder
