GR-55 - Hipshot piezo 6string bass bridge -> hexpander -> GR55
Started by Steve_the_bass, August 30, 2016, 08:18:41 AM
Steve_the_bass
Hopefully I'm in the correct forum with this...
I've been using an external GK3-B for a while on this bass, which works fine, but unfortunately means I can't get it in the hard case, and I'm unhappy having it in a soft case in the back of the van where amps etc can fall on it, soooo, as it already had a piezo bridge installed, I decided to try and connect the piezos to a 13pin socket using a hexpander board.
I got everything connected up, the gr55 gets the note information from the hexpander fine, but I can't reduce the level of the sensitivity enough to remove false triggering. Has anyone else experienced this and come up with a solution?
fokof
Sorry , I don't know the GR55
You should ask in the GR55 section
Steve_the_bass
Quote from: fokof on September 02, 2016, 05:47:36 AM
That's probably a good point, I'll post in there too, thanks :)
