Need pic of Godin xtSA wiring to 5-way Switch (HSH)
Started by Nathan Shane, May 30, 2016, 09:47:16 AM
Nathan Shane
Hi everyone...I've run into a bit of a jam. I had previously replaced all the HSH pickups in my Godin xtSA and then removed them a couple years ago. So the guitar has been sitting unused and without pickups for quite some time. This weekend I decided to put all the original pickups back in. My problem is, is that I can't find the drawing I made of which wire is soldered where on the 5-Way Switch. The 5-Way Switch on my Godin xtSA looks like a thin square box and has only 8 leads (all on one side) that you can solder to.
Would it be possible for someone to take a very clear photo of the wiring of their 5-Way Switch or if anyone has a Godin xtSA wiring diagram, that would probably work as well. I've searched this forum and the Internet for a photo/diagram of the wiring, but there just isn't one that is clear enough or has a different 5-Way Switch.
Any help would be greatly appreciated...thanks!
Nathan
