Smartphone TRRS Headset cable Adapter?
Started by mbenigni, May 17, 2013, 11:16:49 AM
QuoteRumors of death of the 3.5mm connector have been highly exaggerated
https://en.wikipedia.org/wiki/Phone_connector_(audio)
http://www.maxsolutionsllc.com/white-paper
https://www.itu.int/rec/T-REC-P.382/en
http://standards.globalspec.com/standards/detail?familyId=JZDERFAAAAAAAAAA
On July 29th without much fanfare ITU-T standardization committee approved a new "recommendation P.382". The standard specifies critical physical and electrical-acoustical characteristics for the universal headset interface with more than 4 terminals. To put it in other words, the geometry and technical requirements for 3.5mm audio plugs and jacks that have 5 (or more) separate communication channels were outlined and standardized. That's right, good old TRRS audio connector featured in  billions of audio devices used and produced anew each year is about to get a huge makeover.
Increasing a number of poles of the 3.5mm audio connector interface has been tried in the past several times. All attempts were not adopted by the market due to issues arising from backwards compatibility with existing 4 and 3 pole solutions currently in use.
However, just recently, MAX Solutions LLC began offering plugs and jacks that comply with P.382 recommendation while providing full backwards compatibility with legacy solutions. Backwards compatibility removes any friction from the market adaption standpoint. All legacy accessories can be connected to MAX TRRRS 5 pole jack without any issues. And vice versa, newly developed accessories with TRRRS plugs will be compatible with legacy 3 and 4 pole jacks. (5th channel notwithstanding)
So what is a big deal shall you say? What difference does one extra channel make?
Increasing a number of separate channels from 4 to 5 could have a huge impact on the market of affordable audio accessories. MAX TRRRS connector interface allows analogue two microphones and two transducers to be connected to a mobile device CODEC simultaneously. Therefore following new all analogue wired accessory applications become enabled:
Inexpensive earbuds with Active Noise Cancelling
Low cost/high performance Wired Hearing Aids and PSAPs
Binaural Recording and Video Conferencing, think Facetime, Skype etc.
Balanced Audio Listening and Recording straight to and from your smartphone
I sincerely hope audiophile community gets as excited about these opportunities as I am. The ground now seems to be staged for a wave of inexpensive all analogue wired advanced audio accessories to start penetrating the market.
It should be fascinating to watch how attempts to rid the world of one of the most popular connector interface in favor of a fragmentation (Apple via Lightning, USB-C) are received and compete with legacy TRRS and MAX's newly developed and standards compliant backwards compatible TRRRS solution.
Are you intrigued? Please visit our web site at www.maxsolutionsllc.com to get further info and contact us for potential future collaboration.
You are equally welcome to discuss this new development in the LinkedIn thread. I would be more than happy to answer any follow up questions.
Oleg Los
MAX Solutions LLC
Founder
Phone: (847) 912 3463
Email: info@maxsolutionsllc.com
http://www.guitarfetish.com/GFS-Guitar-Pickups_c_7.html
Introducing GFS Kwikplug Instantly Interchangeable Guitar Pickups
Most of the famous GFS Pickup designs may now be ordered with our Patent Pending "Kwikplug" system.
All the same tone you've come to expect from Guitarfetish but now change pickups in MINUTES with no additional soldering!
Most of the pickup listed below are in stock in either Kwikplug version or standard solder version. YES you can mix and match- they work fine together.
Solder them up yourself or chose one of our Pre-Wired harnesses that install in seconds with NO soldering.
Once you install ANY Kwikplug pickup you can INSTANTLY switch that pickup out for another Kwikplug pickup! Just plug and play!
Adopted high-performance headphone jack "Pentaconn" made by Nippon
Adopted a headphone jack (5 poles) of φ4.4 mm which can be balanced with a single headphone plug and has excellent connection stability. Resistance value of each channel is closer than φ 3.5 mm, and contact resistance is low, so it is possible to represent sound resolution, spread and depth absolutely.
http://www.sony.jp/walkman/products/NW-ZX300/?s_rcmd=rt_recent_browse_history_products_C5
https://www.amazon.co.jp/AD-4-4mm-5%E6%A5%B5-%E8%87%AA%E4%BD%9C%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF-%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9/dp/B072Q7VLZ2/ref=pd_lpo_sbs_23_img_0/357-6126772-1764000?_encoding=UTF8&psc=1&refRID=YWJSD7V1WSBFYZRJ3RB5
https://www.amazon.co.jp/NOBUNAGA-labs-NLP-PRO-TP4-4-5-4-4mm5%E6%A5%B5%E8%87%AA%E4%BD%9C%E3%83%97%E3%83%A9%E3%82%B0-NLP-PRO-TP4-4/dp/B01N4PA74E/ref=pd_sbs_23_2?_encoding=UTF8&psc=1&refRID=B2RDXRZ7MWVZV4MNGCZ7
https://www.encoredataproducts.com/headphone-adapters-cables/avid-fishbone-flexible-breakaway-trrs-adapter/?gclid=Cj0KCQjw0brtBRDOARIsANMDyka0ghDdKhb961Wd16L-exVaAJbq3pzgfjXCtHbyYgbc7eeDXK9JijQaAnQUEALw_wcB
AVID FISHBONE FLEXIBLE BREAKAWAY TRRS ADAPTER
Pin Breakage Reduction
The AVID Fishbone TRRS adapter is AVID's response to the pin breakage problem experienced across the audio industry by companies of all sizes.
This flexible breakaway TRRS adapter helps prevent pin breakage inside expensive electronic devices when a
student pulls mistakenly yanks the cord when standing rapidly or when a device falls on the ground.
Inspired by the swimming motion of fish, the AVID Fishbone bends in the middle across the ribs while rotating in the device's jack.
This flex-and-bend reorients the AVID Fishbone's jack in the direction of the pulling force allowing the headphone pin to disengage
without causing damage.
Available in any color as long as it's green, the Fishbone is part of AVID's targeted approach to increasing time on
learning by reducing technology failure.
