VG-99 - Led Zeppelin - Dancing Days
Started by Brent Flash, April 21, 2008, 07:44:28 PM
Tricky stuff going on with this patch. If you have seen this patch from me before this is a whole new approach to it. I have been trying to get as close to the recording & be able to play it that way live. It is possible as you can hear in the demo. You will need the FC-300. Start with EXP PEDAL 1 back for the intro and then when you get to the verse push it all the way forward. This will change the 1st string tuning and change the tone. The first three strings are tuned the same until you push the pedal forward, play them all with the slide. Ask if you need help figuring out how to play it.
I play it with a slide but you can do it without. It just does not have that zing in the tone the slide gives you.
Mp3 demo and patch below. You must be a member and signed in to see the files to download.
troy mcclure
New member here this patch sounds awesome..
Quote from: troy mcclure on September 02, 2008, 02:23:16 PM
Thanks Troy! And welcome to the group!
This one is a little tough to play.  ;D
