JTV - Anybody installed an internal GK3 on a tyler variax yet?
Started by pappywatts, August 09, 2011, 02:23:07 AM
burningyen
Ben
www.burningyen.com
www.b-wayguitars.com
Thanks Ben for the great info, I'm still thinking of building a Lefty out of the new TTV89 sitting in my office. Just need the time
chainsawdave
Quote from: Elantric on March 18, 2015, 11:55:24 AM
Check 1/4" TRS Output with Ohm meter
Tip = analog Guitar OUT
Ring  = +7VDC Power
Sleeve = Ground / Earth
FWIW - i did locate this on the net - from the old Line 6 forum  - but its targeted for adding internal GK-KIT-GT3 to a Variax - and use the existing Piezo saddles to drive both Variax DSP board and Roland GK board
Suggest read this thread too
Schematics
Unfortunately the web links are broken. I have a different challenge but related. I have a Roland VG Fender with I suspect the GT3 pick up. I'd like to use the Variax piezos. Has anyone tried this? It's similar to the above but as the link is gone I could not check.
QuoteI have a Roland VG Fender
Schematics
GC-1 Wiring
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=73.0;attach=9749
GK-Kit-GT3 Manual
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=73.0;attach=10157
G-5 VG Strat Wiring
https://www.web.archive.org/web/20150905162653/https://support.fender.com/service_diagrams/stratocaster/011-7500C_SISD.pdf
Roland G5 Strat / Fender VG Strat- can 13 pin connector be added? (like GC1)
https://www.vguitarforums.com/smf/index.php?topic=1648.0
chainsawdave
Really nice piece of work. I'm a total noob and just learning about modelling. I have a question are the transducers in the GK3 piezos like on the JTV? If so is there much difference in the output?
mooncaine
No, the transducers in the GK pickups are magnetic pickups that function pretty much the same as your normal electric guitar pickups, except they're smaller and there's one for each string.
Some say that a VG's electric guitar emulations sound best if you use a magnetic pickup instead of a piezo. I believe that this is true.
