Meris - Polymoon
Started by Elantric, November 19, 2017, 07:21:36 PM
https://www.meris.us/product/polymoon-pedal/
ANGELO MAZZOCCO
DSP ENGINEER/VP
I've always been mesmerized by how giants like Holdsworth and Zappa would push rack delays to their limits.   I designed the Polymoon's algorithms as a tribute to those sounds while offering an even wider palette of dynamic echoes
UNLOCK YOUR DREAM STATE
Brain Tides
Tidal soundscapes and super-modulated repeat trails will lead to new inspiration with every note you play. Guitar, synthesizer or any instrument will take on new shapes and forms with the Polymoon's massive algorithmic flow.
Sound Clips
Expression Pedal Advanced Modulation
Audio PlayerVideo Player
Use Up/Down Arrow keys to increase or decrease volume.
Multiply 3 with Sync Phase
Stereo Dynamic Doubling
Pitch Delay with Half Speed
Skipping Phaser Delay
Dimension Reflections
Pitch Delay
Multiply 3 Tap Tempo
Multi-Voice Chorus
Subterranean Flange Echo
Time Bending Fuzz
Dark Delay Modulation
Trapped Echoes
THE CONTROLS
Explore Polymoon
Click the (+) signs to learn more
Features
Specs
Super-Modulated multiple tap delay
1200mS real time selectable multiple-tap delay line
Massive multi LFO modulation controls
6 custom tuned LFOs with adjustable waveforms for subtle to aggressive pitch shifting effects
Adjustable Tilt EQ filter in delay feedback
Tempo syncable stereo Barberpole Phaser
Multimode stereo Dynamic Flanger w/ feedback
Unique feedback topology
Dimension control for smearing reflections
Selectable quarter or dotted eighth note Tap Tempo
Digitally controlled Analog mix control
Stereo input and output
Switchable input output headroom level for Guitar, Synthesizer or Line levels
Expression pedal control over all parameters simultaneously
Presets available via external 4-Preset switch or MIDI
MIDI in/out over TRS via the EXP jack
External Tap Tempo over TRS
MIDI beat clock synchronization
Premium analog signal path and 24-bit AD/DA w/32 bit floating point DSP
Premium Analog Devices JFET input section
Color – white powder coat with fine iridescent flake
Designed and built in Los Angeles, California U.S.A.
Manual
Download Manual
https://www.meris.us/wp-content/uploads/2017/07/Meris_Polymoon_Manual_v1g.pdf
Smash
Late entry for gear of the year?
Some great sounds on there - the smearing delay is gorgeous- how is that done?
When the foot pedal is slammed reminded of that Tom Scholz contraption!
Also brilliant demo - adjusting controls realtime on a continued loop.
Quote from: Smash on November 20, 2017, 09:32:06 AM
Agreed  - I just ordered one  - only place that had one was Mesa Boogie Store in Hollywood
https://mesahollywood.com/
https://mesahollywood.com/products/meris-polymoon-delay-pedal
Compact, pedalboard friendly MIDI I/O for up to 4 Meris pedals
Allows control of all parameters via MIDI
Supports MIDI input and output from all Meris pedals
Allows unlimited offline preset saving and loading
Wireless compatibility with bluetooth MIDI adapter
MIDI in and out activity status LEDs
Also compatible with Empress and Chase Bliss* pedals (*requires special cable)
** 9V Power supply not included
https://www.meris.us/product/midi-i-o/
Mitchelldream
2 points
2 months ago
edited 2 months ago
I've been trying to perfect this layout for weeks! You can download this layout on the midi designer forum page for free but the app costs about $30 for all the features. link: http://mididesigner.com/qa/6606/layout-meris-polymoon-layout There is so much you can do with midi on the iPad and the Meris pedals, I won't go into it all again but if you want more detail about what it can do I'm making youtube demos here -
ElliotG
I created an editor for the Polymoon... Link to github in the video comments.  Available for Windows and Mac.
