FC-1 and Logic Pro X integration
Started by hibikionkyou, August 21, 2017, 10:44:45 PM
hibikionkyou
Hi
Can the FC-1 be used to change patches in other DAWs, such as Logic Pro X?
I have Logic Pro X and I purchase the FC-1 thinking that this would be possible (not enough research perhaps) but now it seems like the FC-1 doesn't change anything on Logic Pro.
I'm starting to think I may have made a mistake in purchasing the FC-1...  ???
Regards
Adam
hibikionkyou
Found the answer here: https://www.fishman.com/products/series/tripleplay/tripleplay-fc-1-controller/
Control the TriplePlay Application
Use the FC-1 to control your TriplePlay Windows or Mac application.  Change patches, connect an expression pedal, sustain, loop and hold with the TriplePlay factory and user patches, or reprogram the buttons to send custom MIDI information.
Control External Sound Modules or Keyboards
With the FC-1, you can now use TriplePlay to plug directly into an external MIDI sound module or keyboard, without a computer attached!  Simply remove the USB receiver from your Mac or PC and insert it into the TriplePlay FC-1 Controller's USB host port. The incoming MIDI data is then passed wirelessly from the guitar to the conventional 5-Pin Din output for use with any MIDI-equipped hardware.
Programmable foot switches and expression pedal input
Three programmable switches default to patch selection, hold, tuner access, and TriplePlay sensitivity settings, with the added ability to program each to send a separate MIDI CC as a momentary or latched controller. An additional programmable expression pedal input allows you to control volume or any other MIDI CC as well!
Programmable Hardware Presets
A large graphic LCD displays the currently loaded hardware synth patch.  All the hardware patches are stored on the controller and can be programmed with the TriplePlay software so you can load the exact sound you need immediately!
