Zoom U44
Started by admin, August 04, 2017, 12:18:43 PM
THE CENTERPIECE OF YOUR MOBILE STUDIO
ZOOM U-44
4in/4out, Handy Audio Interface
The U-44 is a compact, 4-in/4-out audio interface that enables you to record and perform wherever you are. Small enough to fit in the palm of your hand, the U-44 comes equipped with the features you need to record 24-bit/96 kHz audio anywhere.
The U-44 offers the same high-quality, low-noise mic preamps as our acclaimed H5 and H6 Handy Recorders, plus compatibility with Zoom's Interchangeable Input Capsules for incredible possibilities. Use the U-44 with your PC, Mac, or iPhone/iPad via USB—or as a standalone AD/DA converter and mic preamp. No other audio interface provides this much versatility, value, and performance.
The World is Your Studio
Wherever you want to record, the bus-powered U-44 forms the perfect centerpiece of your mobile studio. Connect instruments, monitors, and other devices when you're recording at home—or hook it up to your iPhone/iPad* to make music on the go. If bus power isn't available, the U-44 can run on just two AA batteries, allowing you to record anywhere.
* Requires 2 AA batteries or optional AC adapter for power, plus an Apple iPad Camera Connection Kit or Lightning-to-USB Camera Adapter for connection to iPhone/iPad.
Can your interface do this?
Thanks to its 10-pin Zoom connector, the U-44 is compatible with all of our interchangeable input capsules (sold separately), representing a powerful field recording setup. Choose from six capsules—X/Y, Shock Mount X/Y, Mid-Side, Shotgun, Stereo Shotgun, and Dual XLR/TRS Combo Input—each with its own unique applications. Record the audience during your live performance, or connect our SSH-6 Stereo Shotgun for dialogue and sound design on your latest film project.
Six interchangeable mic capsules that can be swapped out as easily as the lenses of a camera
u44
shotgun
SGH-6 SHOTGUN CAPSULE
ALL THE PICKUP,
HALF THE LENGTH
The SGH-6 Shotgun capsule is a hyper-directional microphone that's perfect for film, live theater, and newsgathering applications.
LEARN MORE
xlr
EXH-6 DUAL XLR/TRS COMBO CAPSULE
EXPANDED CONNECTIVITY
Plugging in the EXH-6 Dual XLR/TRS Combo Capsule gives you two more inputs, perfect for connecting extra microphones, instruments, mixers, or portable music players.
LEARN MORE
shotgun
SSH-6 STEREO SHOTGUN CAPSULE
THE BEST OF BOTH WORLDS.
The SSH-6 Stereo Shotgun capsule adds a super-directional mic for capturing sounds directly in front, plus a bi-directional one for capturing ambient sounds. It's ideal for location recording, allowing videographers and content creators to capture dialogue or narration with the center microphone and mixing in the desired amount of environmental sound captured by the side microphone.
LEARN MORE
xy
XYH-6 X/Y CAPSULE
LIVE RECORDING PERSONIFIED
The XYH-6 X/Y capsule features two matched high-quality unidirectional microphones, and delivers excellent results for all types of live stereo recording.
LEARN MORE
ms
MSH-6 MS CAPSULE
THE ULTIMATE IN IMAGE CONTROL
The MSH-6 Mid-Side capsule contains two mic elements positioned directly on top of one another. With dual mic elements—a forward-facing, unidirectional mic (the "Mid") and a side-facing, bi-directional mic (the "Side"), the Mid-Side recording technique allows you to adjust the width of the stereo image after it has been recorded.
LEARN MORE
xyh5
XYH-5 X/Y SHOCK-MOUNT CAPSULE
LOUDER. CLOSER. CLEANER.
The XYH-5 X/Y shock mount capsule features two matched unidirectional condenser microphones housed within an advanced shockmount to minimize vibration and handling noise, perfect for loud concert and performance settings.
LEARN MORE
shotgun
ALL THE PICKUP,
HALF THE LENGTH
LEARN MORE
xlr
LEARN MORE
shotgun
LEARN MORE
xy
XYH-6 X/Y CAPSULE
LEARN MORE
ms
MSH-6 MS CAPSULE
LEARN MORE
xyh5
LEARN MORE
Pristine Recording and Playback
Inspired by our Zoom H-series recorders, the U-44 is equipped with high-performance, low-noise mic preamps that enable recording and playback at resolutions up to 24-bit/96 kHz. You can also use U-44 as a studio-quality headphone amp and listen to your favorite music in full fidelity.
It's All About Connections
The U-44 features a full array of inputs and outputs so you'll always be prepared for any recording or live performance. Two combo inputs with independent gain knobs and multi-color level indicators provide flexibility for connecting mics, keyboards, and mixers. 48V phantom power can be supplied to inputs 1 and 2, and input 1 supports Hi-Z input for connecting passive guitars, basses, or other instruments. MIDI I/O jacks enable synchronization with devices like electronic keyboards, controllers, and synthesizer or sampler modules.
Multiple output options—including 1/4", RCA, and S/PDIF—allow you to connect DJ mixers, speakers, and more. Monitoring your mixes is easy thanks to a dedicated headphone output with independent volume control. The direct monitor knob makes it possible to blend your headphone mix between the input and playback signals—perfect for live electronic music performance and DJ'ing.
Control Your Mix
With advanced monitoring options, the U-44 lets you dial in your ideal mix. Create a balanced headphone mix between your click track and main out signals during live performances. Or balance the cue and main out signals when you're DJ'ing. The outputs of channels A and B can be muted, providing even more control. Plus, direct monitoring enables you to hear the live signal you're recording without latency—simply adjust between the input and computer playback signals to create the perfect mix.
Standalone AD/DA Conversion
Transfer audio with total clarity
When you're transferring audio, high-quality AD/DA conversion is critical. The U-44 functions in standalone mode as a high-quality mic preamp and AD/DA converter to ensure complete transparency when converting audio formats. You can choose between a 44.1 or 48 kHz sampling rate for conversion.
Connect digital audio gear to analog amps and mixers
Create digital samples for your songs
Digitize your analog records and tapes
Transfer archived recordings to digital
Feature-Rich Mobile Recording
The U-44 is small enough to carry in your jacket pocket or backpack—without sacrificing features. Plus, all of the connectors and knobs are strategically positioned for fast access.
Create More with Your U-44
Includes Albeton Live 9 Lite
With the U-44 and Ableton Live 9 Lite, you have everything the modern music creator needs. Record your tracks quickly and intuitively, enhancing them with studio-quality effects like EQ, compression, reverb, delay, chorus, filter, and more. Plus, Ableton's performance workflows let you take your music to the stage where you can mix and record live. Plus, Ableton's performance workflows let you take your music to the stage where you can mix and record live.
Features at a Glance
Multi-channel and stereo USB audio interface for PC/Mac/iPhone/iPad
Connect to iPhone/iPad with Apple iPad Camera Connection Kit or Lightning-to-USB Camera Adapter (sold separately), plus 2 AA batteries or optional AC adapter for power
Two mic/line inputs with high-performance mic preamps
High-quality recording and playback at resolutions up to 24-bit/96 kHz
Compatible with Zoom interchangeable input capsules via 10-pin connector
Standalone AD/DA conversion
Functions as a two-channel mic preamp with analog and digital outputs
Approximately 4 hours of operation with 2 AA alkaline batteries
Includes download code for Ableton Live 9 Lite
Four-channel simultaneous inputs
Hi-Z support (input 1)
Zero-latency direct monitoring
Three TRS phone jack outputs
Dedicated RCA L/R and headphone outputs
MIDI I/O
S/PDIF optical/coaxial input and output
Gain control knobs for each input
+48V phantom power for inputs 1 and 2
Accepts standard AA alkaline or NiMH rechargeable batteries
Accessories
Here's what's included with the U-44 Handy Audio Recorder...
Operation manual
Ableton Live 9 Lite software download code
USB Cable
Optional U-44 accessories
XYH-6 X/Y mic capsule
XYH-5 X/Y Shock-mounted mic capsule
MSH-6 Mid-Side mic capsule
SGH-6 Shotgun mic capsule
SSH-6 Stereo Shotgun mic capsule
EXH-6 Dual XLR/TRS combo input capsule
ECM-3 Extension Cable for Zoom mic capsules (3m)
ECM-6 Extension Cable for Zoom mic capsules (6m)
Zoom AD-17 power supply
AIH-1 Audio Interface Holder
https://www.zoom.co.jp/sites/default/files/products/downloads/pdfs/E_U-44_0.pdf
https://forum.audiob.us/discussion/15292/zoom-u-24-impressions
ronkmd
But the U-44 has SPDIF Optical /Coax and is 4in/4out -and works as standalone 24 bit ADC and DAC
And iPhone /IPad
If only it were 32 bit I/O
Hurricane
;D Close but no cigar  8)
EZ :
HR
