Katana - Fs5l foot switch and fx
Started by Wehrwulfe, July 03, 2017, 02:01:56 PM
Wehrwulfe
If I plugin the fs-5l ftswitch into the gac controller can I switch the fx off and on  if the patch is written in the boss app or the "sneaky amp app for android??(I would to keep the delay on with unvibe or rotary)
The GAFC socket is ONLY for the GAFC controller,
it is a serial proprietary data controller with integral power supply in the TRS (stereo jack) socket.
Plugging in a FS-5L foot switch into the GAFC socket will only toggle a short circuit of the Katana controller power supply.
Wehrwulfe
Not into the socket..into the fx jack on the pedal. If an expression pedal will control a wah(off/on etc)shouldn't it control any other fx in the fx tab??
Wehrwulfe
I didn't say anything about plugging into the socket. The post says into the gac pedal
Sorry I misunderstood your question,
into the FX Expression pedal controller input of the GAFC will be no advantage, the FX input only does WAH while the WAH effect is engaged, otherwise it only controls Volume.
Unfortunately the FX EXP controller is not assignable for any other effects (which is disappointing).
Wehrwulfe
Bummer !but thank you for the clarification.. I want to try the floorboard app next....big props Gum
