ATG - Thinking of getting one. What should put me off?
Started by BobTheDog, April 24, 2017, 01:32:22 PM
cags12
Quote from: Elantric on August 18, 2017, 01:40:45 PM
Actually this should be straight forward  - the MIDI Designer ATG template contains most  MIDI controls for ATG
My goal is to not depend on a PC/MAC to create presets, specifically alternate tunings. On the Luthier KIT and AT-200, it is not possible (AFAIK) to set up the pitch coefficients to the cent. The MIDI designer Layout is not capable of doing this either. It is only built based on the MIDI CC reference. Presets are pushed to the board via Sysex.
I tried to sniff the communication with MIDIOX but for some reason when this is running, the presets manager only communicates partially with the guitar and throws an error. Besides, it does seems to be very complex so a little help here would be great.
QuoteMy goal is to not depend on a PC/MAC to create presets, specifically alternate tunings.
For Antares internal kit / AT-200 users  - try the "Fret Control method"
http://www.autotuneforguitar.com/support/documentation-detail.php?help=Fret_Control_44
cags12
Quote from: Elantric on August 18, 2017, 02:30:23 PM
Fret control is not accurate for creating custom alternate tunings. They would not be exact as setting up the coefficients.
If you are seeking micro tonal  / non western tunings  / scales- IMHO  you will be extremely frustrated with the Antares ATG
its goal is to align all notes to be in "perfect western pitch" - you either enjoy this, or feel it gets in the way of your guitar artistry
I would not use use ATG  for playing middle eastern music
https://youtu.be/RWCwMW48FO4
https://www.vguitarforums.com/smf/index.php?topic=2245.0
https://www.vguitarforums.com/smf/index.php?topic=2245.msg127977#msg127977
this sums it up
http://line6.com/support/topic/3061-autotune/
QuoteIt sounds interesting for sure.  But being a fan of eastern microtonal music and the Hendrix junkie that I am, I would need the ability to disable the correction.
cags12
Quote from: admsustainiac on August 18, 2017, 03:39:17 PM
I am not at all looking for microtonal but to have a repertory of different tunings. Even very low Bass ones.
What I meant is this (below):
Quote from: cags12 on August 18, 2017, 03:47:09 PM
Then use the ATG Manager to create custom tunings and store them as presets
QuoteHi guys,
I'm thinking of picking one of these up.
look in the used channel  - Antares ceased all development for the ATG Guitar hardware and dropped support in 2017
