Quantiloop - Live Quantizing Looper
Started by Elantric, February 02, 2017, 01:03:02 PM
https://itunes.apple.com/gb/app/quantiloop-live-quantizing/id1156213359?mt=8
Description
Built for Live performance and hands free use, Quantiloop recreates the simplicity of a hardware loop pedal in an iOS app. Attach a MIDI foot controller and control it the way you want. No MIDI controller at hand; just preset your loop length, enable auto–record or a count–in and your loops will automatically close, no hands or feet required. Big onscreen controls allow for easy configuration and tactile control by vocalists or beat boxers. Focus on your performance instead of fiddling with dip switches or complex menu's.
Be Creative
Create 4 tracks with endless layers of overdubs to build your performance. Record a Chorus, Verse and Bridge and switch between them seamlessly or create a 1 bar percussie loop on track one, a 4 bar chord progression on track two and layer a bass line on top, all in perfect synchronisation.
Rhythm Guide
The builtin rhythm guide provides a rhythmic backing. Use the internal metronome for practice, import drum loops from virtually anywhere or host and control your favourite rhythm apps to enhance your performance. MIDI master lets you control MIDI hardware, and MIDI slave lets Quantiloop follow it. Ableton Link lets you even play in time over WiFi with external apps and devices. Quantisation aligns your actions to the nearest measure or beat so you stay in time, and real-time tempo control sets the pace. Prefer setting your own pace, disable quantisation and Quantiloop will react to your actions with minimum latency to create tight synchronised recordings.
FX
Assign up to 3 simultaneous effects to the input. Use the built-in transpose to covert your guitar into a bass, or host your guitar amp sim directly in Quantiloop. The results will be recorded into your loops.
Or assign up to 3 simultaneous track effects to the output. Use the tape stop to add drama, introduce a key change to build up your performance, or host an Inter-App audio reverb processor. Track FX may be assigned to a single track, all tracks or the combined output.
Features
•   Free, Synced and Serial and Serial-Master Playing Styles
•   Multiple Quantise Modes
•   Multiple Stop Modes
•   Unique Arm Mode
•   Unlimited Overdubs
•   Overdub Decay
•   Undo / Redo
•   Auto Record
•   High quality stereo audio
•   Clear loop status display
•   Rhythm guide with optional auto-start, auto-stop and count-in
•   Audible and Visual Metronome
•   Send start, stop and host sync to hosted rhythm apps.
•   Sync to host when embedded in an Inter-App-Audio host
•   Real-time Tempo Control
•   Extensive MIDI control
•   Multiple Assignments per MIDI controller (tap, hold, double tap)
•   MIDI Program Change support for changing presets
•   Supports Audiobus and Inter-App-Audio
•   Individual outputs for each track and rhythm
•   Synchronise to other apps and devices with Ableton Link
•   MIDI clock sync (both slave and master)
•   3 assignable input Fx, including transpose, reverb and IAA
•   3 assignable track Fx, including transpose, reverse, tape stop, fade and IAA
•   Cloud (iCloud, Dropbox, Audioshare ...) import / export
•   AudioCopy/Paste
•   Open In
•   Store Phrase Presets in unlimited banks with 32 presets each
•   Individual Volume and panning controls for each track
What's New in Version 2.0
This is a Major Update with lots of new features:
- Completely refreshed UI
- 4 Tracks + Rhythm Track
- New play mode: Serial Master
- Assignable Instant Track FX (Fade, Tapestop, Reverse, Transpose, Reverb/Delay, Comp/Gate or any IAA effect)
- Assignable Instant Input FX (Transpose, Reverb/Delay, Comp/Gate or any IAA effect)
- Arm Mode enhances workflow dramatically
- MIDI Slave support (E.g. slave Quantiloop to your hardware drum kit)
- MIDI Program Change support for changing presets
- Many stability improvements
http://www.musicradar.com/news/quantiloop-2-is-like-a-looper-pedal-on-your-ipad
Stephan Marx's Quantiloop 2 is designed to look and behave like a 4-track hardware looper pedal. An update to the original Quantiloop, it's available now for iPad.
There are four play modes, including the new Serial-Master mode, and you also get three assignable  input effects and  three assignable track effects. The likes of tape-stop, fade, reverse and transpose are on offer within the app, and you can also use Inter-App Audio effects. The MIDI slave option means that you can sync to external gear.
A full feature list is below. Quantiloop 2 is available now from the Apple App Store priced at £9.99/$9.99/€9.99.
Stephan Marx Quantiloop 2 features
4 Tracks
Free, Synced, Serial and Serial-Master Playing Styles
Multiple Quantize Modes
Multiple Stop Modes
Unique Arm Mode
Adjustable Fade Out and Fade In
Unlimited Overdubs
Overdub Decay
Undo/Redo
Auto Record
Rhythm guide with auto-start, auto-stop and count-in
Audible & Visual metronome
Input FX (including transpose, reverb and IAA)
Send start, stop and host sync to rhythm apps
Real-time tempo control
Assign Tap, Hold and Double Tap actions
Audiobus & Inter-App Audio
Individual outputs
Ableton Link
MIDI clock master
MIDI slave
MIDI program changes
Cloud Import/Export
Unlimited banks of 32 presets
Track FX (tape-stop, fade, reverse, transpose etc. and IAA)
