GR20 - no synth sound
Started by feefop, November 19, 2016, 11:51:15 PM
feefop
Just got a GR 20, using with an old GK2 pickup.  I get guitar sounds to go through when I set the GK2 to guitar, but no synth sounds.
I'm not using a Roland GKC 13 pin cable, but instead a cheap one off of ebay.  Is that the problem?
nix808
Maybe try doing a factory reset?
edit- also, here is a real similar thread:
https://www.vguitarforums.com/smf/index.php?topic=16281.0
Rock and Rock my boat, as long as you don't rock and rock my boat!hehe
To verify your 13 pin cable is suitable for Roland Boss GK 13 gear.
Use an ohmmeter and verify the DIN 13 male plugs have each individual internal wire connected in a 1:1 fashion for all 13 pins.
No shorted adjacent pins
Sadly many eBay cable are incorrect for Roland GK 13 use , as these were Kenwood /Clarion external CD player cable , and some can Cause damage to Roland /Boss gear.
A lot of cables on eBay are for car stereos and do not work   Recommend a Roland cable or from our own  Primova ,Gumbo or Gittler
feefop
how do  I get ahold of these guys selling roland 13 pin cables?  Any other way besides private messages?
feefop
Still having issues....have a roland gk13 cable now.
Using it with an older gk2.  On the synth setting I get a muffled guitar sound only, like the tone knob is all the way down.  Man, this is painful....any help?
QuoteI'm not using a Roland GKC 13 pin cable, but instead a cheap one off of ebay.  Is that the problem?
Sad to inform - that cheap ebay Gk 13 pin cable might have damaged your GR-20
It shorts the +7VDC rail (pin #12 ) to ground,and "poof" goes the Roland GR-20
Be advised 90% of the ebay sellers for 13 pin Roland cables are actually reselling old Kenwood Ham Radio / car stereo CD changer cables and these can damage your Roland / Boss gear big time!
read this thread
Latest on GK 13 pin Cable Sources
https://www.vguitarforums.com/smf/index.php?topic=1584.0
QuoteAny other way besides private messages?
Straight to Straight 13 Pin Midi Cable with Locking Connectors, made with CA-0842 Shielded 13 Conductor Midi Cable.
Compatible with Roland guitar synths.
https://btpa.com/13-Pin-Midi/
https://www.amazon.com/gp/product/B01CPKKVSI/ref=s9_acsd_hps_bw_c_x_2_w
feefop
really?  Wow, that reallly F'n sucks.  Could it be the GK2 itself?
I bought that 13 pin cable that was a kenwood cable, off a guy from ebay.  Can i go after him for selling me a cable that damaged my equipment?
Quote from: feefop on December 07, 2016, 09:29:02 PM
Sadly, I'll bet the fine-print will NOT be in your favor...
...you would probably have more chance of going at him through eBay for false advertising, but I wouldn't put money on that either.
..and as Yoda would say, "Sucks it does!"
feefop
That would be up to a Roland service call methinks.. :-\
feefop
I paid $140 for it....probably cost that much to have it fixed, if not more...probably should just get another one, now that I thin more about it.
Just trying to get into the roland synths, and it's been a frickin' headache getting all the parts and now a nightmare with a fried GR20.  Maybe that's a sign to stay electric! :)
kenact
Quote from: feefop on December 10, 2016, 11:35:35 PM
If you're in the NYC area, I can recommend an authorized Roland Service Center in Brooklyn.
Amp & Guitar Wellness Center
1700 10th Ave
Brooklyn, NY 11215
(718) 369-7080
Danoblaster Baritone w/GK-3
Gretsch Nashville, Viking
Fender Strats
Fret King Supermatic
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
feefop
I'm in the SF bay area....maybe I'll find out a cost for repair then sell in on ebay for parts.....what a frickin' mess this turned out to be.  I'm still pissed!
kenact
Quote from: feefop on December 11, 2016, 09:40:28 PM
I'm still pissed!
It's better to be pissed off than pissed on. :)
Before getting crazy, are you getting signals to the GR-20 from the GK2?
Have you done the factory reset?
Can you use the tuner on the GR-20?
Have you been able to set the sensitivity?
If so, which output are you using. For Mono, it should be the OUTPUT/R (MONO).
Have you tried adjusting the LEVEL?
If you're unable to use the tuner, what position is the GK-2 switch in, GK, MIX or GUITAR? to get synth sounds, it should be in GK or MIX.
Fender Strats
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
