FTP Hardware Synths on Triple play software, different channels, is it possible?
Started by KuRi, October 03, 2016, 08:15:11 AM
KuRi
Hi!
I am struggling to use 2 hardware synths on triple play software (to send midi to external synth module) and use more than one channel. What I want is:
- x1 hardware synth that receives all string on channel 1
- x1 hardware synth that receives all string on channel 2
I am able so send each string to separate channels, but that's not what I want. What I want is to send all strings to channels 1 and 2 at the same time, then choose two different midi instruments on the external synth to play several instruments at the same time.
The external synth I am using is the Roland SD-50, connected through 5-pin midi.
Thanks!
KuRi
Smash
It will help if you describe the set-up
Are you using FTP in hardware mode or is FTP connected to your PC and then midi out from PC to SD50?
GuitarBuilder
Quote from: KuRi on October 03, 2016, 08:15:11 AM
Hi!
Thanks!
It's unclear to me why you want to use different channels if you are sending the identical MIDI data to each synth.
