Reverse engineering GK3 for specific MIDI output application, help needed please
Started by raccio14, April 12, 2016, 05:19:09 PM
raccio14
I'm a 5th year Electrical Engineering student at Georgia Tech, working on my senior design project.  Roughly, the idea of the project is to use the data from a hexaphonic pickup to create a program to automatically output a tab of what a guitarist is playing, ideally as close to real time as possible.
Given that the hexaphonic pickup is capable of providing analog sound signals from each string separately, the idea is as follows:
The data from each string will be read separately as frequency and duration data for each note.   By knowing the frequency of the note, and the string that it was played on, the position of the guitarist's fingers can be extrapolated.   If need be, additional capacitive sensors will be placed along the neck of the guitar for confirmation of hand position to assist with error correction.
Currently the team has decided upon trying to use a Roland GK-3 pickup and making our own circuit to interpret the output.   My problems are as follows:
Is there a good way to convert the analog sound information from the GK3 into MIDI information that can be fed to the computer?   If we can use MIDI information, frequency data will be readily available and should assist in the programming.
Additionally, how is the GK3 unit powered?   I've found the circuit schematic on the forums, but it seems incomplete: https://www.vguitarforums.com/smf/index.php?topic=4729.0
I've explored a bunch of the breakout boxes on Bill Bax's website, and it seems that he and other members here have access to schematics for the GK3 and related accessories.   Currently, I think that the best way to do this would probably to use a breakout circuit to split the 13-pin cable to 6 buffered outputs, similar to some of the breakout boxes that you have.   Each of these signals will need to be fed to separate MIDI converters (or one multiplexed, if possible), so that frequency, envelope, and string number data can be fed to the computer for the program to analyse.
Ideally, this would all be simulated on a circuit level, and a custom PCB will be printed for our conversion unit with USB or MIDI output.
If you have any suggestions on the best way to make this happen, I'd greatly appreciate it.   Any circuit schematics, specifications, or other tips/tricks you have involving the GK-3 and related accessories are definitely needed.
Really the things I'm trying to figure out now are:
1.  How power the GK3 and start reading analog signal data out of the 13 pin DIN, like with a scope.
2.  Buffering that data and turning a copy of it into MIDI (schematics from the GI-10 would probably be helpful for this)
Thanks!
HAMERMAN409
A GK-3 is normally used in conjunction with a device (GR-55, GR-33, GR-30, VG-99) that would feed it power.
To do what you want with minimal hardware you probably want to connect the GK-3 to a 13 pin DIN connector using a Roland 13 pin hex cable. You would then have to provide +7V and -7V power to the DIN connector to power the GK-3. You could feed each of the six string output signals into 6 different channels of a sound card. You may need to add some gain to each of the six signals. When processing keep in mind that any given string signal may (and probably will) have some signal from the adjacent string on it.
You might want to have a look at the Fishman Triple play, it is a hex pickup, hex2midi converter, and wireless to USB receiver dongle.
It already does much of what you are wanting to achieve.
Otherwise, the GK 13 pin system uses the shield (outer shell) for a common ground,
pins 1~6 are the strings 1~6,
pin 12 requires +7 volts,
pin 13 requires -7 volts
(0 volts is common to ground).
You might be able to build something using an Arduino,
it does 10 bit A/D, but midi notes only require 7 bit, the Teensy 3.2 should be plenty powerful enough.
If you want to power a GK-3 from single source supply (a battery cell), then one of these will provide the split rail supply
http://www.ebay.com/itm/3W-DC-Boost-Converter-3-3V-10V-to-12V-Step-up-Power-Module-replace-LM78XX-79XX/301906594702?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36213%26meid%3D0e20a2a8f8d9422192307abf9e7f3ce4%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D201413161834
by adding a 6.8 k ohm resistor from the + output back into the circuit, it will give you +7 and -7 volts
I have (long time ago) done pitch to midi conversion with a micro, use the analog input to measure amplitude and trigger threshold, and also boost the input signal to square wave and use digital inputs to measure duty cycle (i.e. the note pitch).
That should give you half cycle note detection (minus string attack transient peaks).
GraemeJ
Quote from: raccio14 on April 12, 2016, 05:19:09 PM
If this is purely an engineering exercise, then have fun.  Otherwise, it seems to me, you are trying to re-invent the wheel.
The raison d'être for the hex pickup is to provide midi information.  The analogue signals are converted to midi within a dedicated synthesiser (roland GR 33, for example) or by a separate unit (Roland GI 20, for example) whose output can be use to control any midi sound engine.
There already exists software that will convert midi to tab (https://midi-to-tab.com , for example).
An interesting project/concept, would be to do the opposite and build a device which can transcribe midi file guitar parts to a hex analog signal which can be passed into a GR/VG unit, as a replacement for the guitar and GK pickup.
QuoteAn interesting project/concept, would be to do the opposite and build a device which can transcribe midi file guitar parts to a hex analog signal which can be passed into a GR/VG unit, as a replacement for the guitar and GK pickup.
A few of us were doing just that back in 1997 , play any 6 tracks of audio (could be from MIDI triggered soft synth)  out a multi channel PC/Mac audio interface feeding the RMC Fanout box which feeds the GK Input on a VG-8.
http://www.rmcpickup.com/fanoutbox.html
but back to the topic
I understand the goal is a learning exercise
read the MIDI Guitar FAQ by  guru Andras Szalay ( inventor of Shadow GTM-6, Axon AX100, Fishman Tripleplay)
http://www.panda-audio.com/midiguitar.php
and read patents
http://www.google.com/patents/US5033353
https://www.google.com/patents/US7732703?dq=midi+guitar&hl=en&sa=X&ved=0ahUKEwjay7qx64vMAhVCKWMKHcWcCNUQ6AEIOzAE
PATENT CITATIONS
Cited Patent   Filing date   Publication date   Applicant   Title
US3571522   Nov 29, 1968   Mar 16, 1971   Bell Telephone Labor Inc   Tone detector
US4217808   Nov 16, 1978   Aug 19, 1980   David Slepian   Determination of pitch
US4523506   Jan 23, 1984   Jun 18, 1985   Hollimon Marshall H   Electronic tuning aid
US4627323   Aug 13, 1984   Dec 9, 1986   New England Digital Corporation   Pitch extractor apparatus and the like
US4688464   Jan 16, 1986   Aug 25, 1987   Ivl Technologies Ltd.   Pitch detection apparatus
US4829872   May 10, 1988   May 16, 1989   Fairlight Instruments Pty. Limited   Detection of musical gestures
US5018427   Apr 10, 1989   May 28, 1991   Casio Computer Co., Ltd.   Input apparatus of electronic system for extracting pitch data from compressed input waveform signal
US5033353 *   Feb 2, 1990   Jul 23, 1991   Fala Joseph M   Note sensing in M.I.D.I. guitars and the like
US5048391   Jun 22, 1989   Sep 17, 1991   Casio Computer Co., Ltd.   Electronic musical instrument for generating musical tones on the basis of characteristics of input waveform signal
US5083491   May 31, 1991   Jan 28, 1992   Burgett, Inc.   Method and apparatus for re-creating expression effects on solenoid actuated music producing instruments
US5218160 *   Feb 19, 1992   Jun 8, 1993   Grob Da Veiga Matthias   String instrument sound enhancing method and apparatus
US5262714   Mar 18, 1993   Nov 16, 1993   Vladimir Friedman   Sinewave frequency measuring apparatus
US5293879   Sep 23, 1991   Mar 15, 1994   Vitatron Medical, B.V.   System an method for detecting tremors such as those which result from parkinson's disease
US5430243   Sep 28, 1993   Jul 4, 1995   Kabushiki Kaisha Kawai Gakki Seisakusho   Sound effect-creating device
US5504270   Aug 29, 1994   Apr 2, 1996   Sethares; William A.   Method and apparatus for dissonance modification of audio signals
US5591931 *   Jan 17, 1995   Jan 7, 1997   Virtual Dsp Corporation   Musical signal multiplexing circuit and demultiplexing system
US5619004   Jun 7, 1995   Apr 8, 1997   Virtual Dsp Corporation   Method and device for determining the primary pitch of a music signal
US5780759   Dec 19, 1995   Jul 14, 1998   Blue Chip Music Gmbh   Method for pitch recognition, in particular for musical instruments which are excited by plucking or striking
US5808225   Dec 31, 1996   Sep 15, 1998   Intel Corporation   Compressing music into a digital format
US5942709   Mar 7, 1997   Aug 24, 1999   Blue Chip Music Gmbh   Audio processor detecting pitch and envelope of acoustic signal adaptively to frequency
US5986201 *   Oct 30, 1996   Nov 16, 1999   Light And Sound Design, Ltd.   MIDI monitoring
US6111186 *   Jul 8, 1999   Aug 29, 2000   Paul Reed Smith Guitars   Signal processing circuit for string instruments
US6166566   Nov 14, 1997   Dec 26, 2000   Linear Technology Corporation   Adaptive threshold circuit for comparators
US6191350 *   Feb 2, 2000   Feb 20, 2001   The Guitron Corporation   Electronic stringed musical instrument
US6525255   Nov 19, 1997   Feb 25, 2003   Yamaha Corporation   Sound signal analyzing device
US6846980 *   Jan 31, 2002   Jan 25, 2005   Paul D. Okulov   Electronic-acoustic guitar with enhanced sound, chord and melody creation system
US7038123   Sep 30, 2003   May 2, 2006   Ludwig Lester F   Strumpad and string array processing for musical instruments
US7102072   Apr 22, 2004   Sep 5, 2006   Yamaha Corporation   Apparatus and computer program for detecting and correcting tone pitches
US7399918 *   Oct 11, 2006   Jul 15, 2008   Gibson Guitar Corp.   Digital guitar system
US7563977 *      Jul 21, 2009   Iguitar, Inc.   Stringed musical instrument device
US7601908 *   Oct 3, 2006   Oct 13, 2009   Ambrosino Eric P   Programmable/semi-programmable pickup and transducer switching system
US20030061931   Jan 17, 2002   Apr 3, 2003   Yamaha Corporation   Discriminator for differently modulated signals, method used therein, demodulator equipped therewith, method used therein, sound reproducing apparatus and method for reproducing original music data code
US20060011052   Jul 7, 2005   Jan 19, 2006   Purchon Jeffrey H   Sound-effect foot pedal for electric/electronic musical instruments
US20060107826 *   Aug 5, 2005   May 25, 2006   Knapp R B   Method and apparatus for sensing and displaying tablature associated with a stringed musical instrument
US20070017345   Jan 4, 2006   Jan 25, 2007   Russell Stoneback   Electromagnetic musical instruments
US20070137466   Dec 12, 2006   Jun 21, 2007   Eric Lindemann   Sound synthesis by combining a slowly varying underlying spectrum, pitch and loudness with quicker varying spectral, pitch and loudness fluctuations
US20070227344 *   Apr 13, 2007   Oct 4, 2007   Line 6, Inc.   Stringed instrument for connection to a computer to implement DSP modeling
US20070256551 *   May 1, 2007   Nov 8, 2007   Knapp R B   Method and apparatus for sensing and displaying tablature associated with a stringed musical instrument
US20080282873 *   Nov 14, 2006   Nov 20, 2008   Gil Kotton   Method and System for Reproducing Sound and Producing Synthesizer Control Data from Data Collected by Sensors Coupled to a String Instrument
JP2002215145A            Title not available
SU1167642A1            Title not available
* Cited by examiner
NON-PATENT CITATIONS
Reference
1      Baalman, Marije A. J.; "The STRIMIDILATOR: a String Controlled MIDI-Instrument"; Proceedings of the 2003 Conference on New Interfaces for Musical Expression; pp. NIME 03-19 to NIME 03-23; Montreal, Canada.
2      International Search Report and Written Opinion from corresponding PCT/US07/81662.
3      International Search Report from corresponding PCT/US08/52940.
4      Karjalainen et al.; Acoustic Sound from the Electric Guitar Using DSP Techniques; Journal; 2000; pp. 773-776; IEEE.
5      O'Malley, Ronan; "Advanced MIDI Guitar Effects System"; Department of Electronic Engineering; pp. 4; National University of Ireland.
REFERENCED BY
Citing Patent   Filing date   Publication date   Applicant   Title
US7982119      Jul 19, 2011   Museami, Inc.   Music transcription
US8035020   May 5, 2010   Oct 11, 2011   Museami, Inc.   Collaborative music creation
US8049091 *      Nov 1, 2011   Sennheiser Electronic Gmbh & Co. Kg   Wireless receiver
US8471135   Aug 20, 2012   Jun 25, 2013   Museami, Inc.   Music transcription
US8494257   Feb 13, 2009   Jul 23, 2013   Museami, Inc.   Music score deconstruction
US9117429 *   Aug 9, 2013   Aug 25, 2015   Fraunhofer-Gesellschaft Zur Foerderung Der Angewandten Forschung E.V.   Input interface for generating control signals by acoustic gestures
US20100154619 *   Feb 22, 2010   Jun 24, 2010   Museami, Inc.   Music transcription
US20100218661 *   Mar 2, 2009   Sep 2, 2010   Sennheiser Electronic Gmbh & Co. Kg   Wireless receiver
US20110209598 *   Feb 28, 2010   Sep 1, 2011   Douglas James Millar   Portable preamplifier for musical instruments
US20140041513 *   Aug 9, 2013   Feb 13, 2014   Fraunhofer-Gesellschaft Zur Foerderung Der Angewandten Forschung E.V.   Input interface for generating control signals by acoustic gestures
* Cited by examiner
Also there is a global abundant mis understanding of what the GK-3 does what format signals are contained in the GK 13 pin cable
Read
How a "13pin MIDI Cable" destroyed the Roland V-Guitar DSP Modeling brand
https://www.vguitarforums.com/smf/index.php?topic=14088.0
if you examine the details of the GK-3, it becomes apparent MIDI data messages have never existed in ANY 13 pin interface from Roland or Any other manufacturer at anytime.
Essentially the GK-3 is a multichannel analog Buffer/Line driver !
https://www.vguitarforums.com/smf/index.php?topic=7893.msg56178#msg56178
Only Roland Japan Corporate Global site tries to clear up the confusion
Roland COSM Reference Library
http://roland.com/V-Guitar/about.html
Tony Raven
