Line 6 Helix Owners Manual
Started by Elantric, September 28, 2015, 08:13:05 PM
Helix Firmware v1.12.0 Release Notes
Helix 1.12.0 is a free update that includes new fixes, stability improvements, and optimizations.
IMPORTANT! READ BEFORE INSTALLING ANY NEW SOFTWARE!
1. Shut down all Line 6 software as well as any software that streams audio, including, but not limited to: iTunes, Spotify, DAWs, etc.
2. Use your CURRENT EXISTING Helix application to back up all of your presets and IRs. If you're running Helix FW 1.06 or 1.06.5, your current Helix application version should be 1.04. If you're running Helix FW 1.10, your current Helix application version should be 1.11.
3. Quit the CURRENT EXISTING Helix application and download and install the NEW Helix editor (1.12.0), available here: http://line6.com/software/ This also installs the newest version of Line 6 Updater (1.09).
4. If you're using Helix Rack with Helix Control, turn off Helix Control.
5. Using the new Line 6 Updater (1.09), update Helix (or Helix Rack) to the newest firmware (1.12.0). If you're using Helix Rack with Helix Control, after Helix Rack has been updated, connect and power on Helix Control, and it will update automatically.
6. Using the latest Helix editor (1.12), restore all user presets and IRs.
New Features
- Compatibility with the full version of the Helix editor (1.12)
Bug Fixes
- A USB port driver issue within OS X El Capitan precluded certain computers (namely MacBook Pros and iMacs from mid-2012) from allowing communication between Helix and the Helix Editor. Note: You must update OS X to El Capitan 10.11.4 - FIXED
- Helix could not correctly respond to incoming MIDI CC #64 (Tap Tempo) - FIXED
- Helix could sometimes not correctly respond to incoming MIDI PC messages after exporting and then reimporting the same setlist - FIXED
- The Tuner screen's Output parameter would not remember its value across power cycles - FIXED
- Changing Input or Output types from the Controller Assign screen could sometimes automatically engage the Learn Controller button - FIXED
- Input > Multi and Input > Variax Tone parameter could sometimes maintain its value across presets, even when set to 'Per Preset'
- Helix Rack's TAP/TUNER button was unresponsive while in Pedal Edit mode - FIXED
- Expression pedals with inverted polarity could cause Helix Rack to freeze when connected to Helix Control - FIXED
- If two footswitches' assignments are quick-swapped while in the Controller Assign screen, the most recent assignment could be removed - FIXED
- The Looper block's icon could incorrectly reflect its state after saving a preset - FIXED
- General stability improvements
- Many other minor bug fixes and optimizations
KNOWN ISSUES
- After a Factory Reset, Global Settings > Ins/Outs > XLR Outputs level appears as Line level but is actually Mic level until you move the knob to "Mic" and back to "Line"
- On rare occasions, if Helix is disconnected from the computer within 10 seconds of shutting down the Helix editor, MIDI transmission may become inactive. Always wait 10 seconds after quitting the Helix editor before disconnecting. If you forget, power cycling Helix solves the issue.
- If you send MIDI CC #59 to Helix, it toggles the control between your bypass-assigned blocks for this switch, but the EXP 1 - EXP 2 Toe Switch strip label does not change states as it does when toggled via the on-board pedal.
Helix Editor (V1.12) for Mac
http://line6.com/software/readeula.html?rid=7025
Helix Editor (V1.12) for Windows
http://line6.com/software/readeula.html?rid=7024
http://line6.com/support/topic/19444-latest-helix-editor-112/
Helix Editor v1.12 Release Candidate Notes
Helix Editor 1.12 is a free update that includes new fixes, stability improvements, and optimizations.
If you have already updated Helix or Helix Rack's firmware to 1.12:
1. Install the 1.12 Editor update, available at http://line6.com/software/. Check the "Beta" box.
If you have NOT already updated Helix/Helix Rack's firmware to 1.12, please follow the instructions below:
3. Quit the CURRENT EXISTING Helix application and download and install the NEW Helix editor (1.12), available here: http://line6.com/software/ This also installs the newest version of Line 6 Updater (1.09).
NEW FEATURES
- Scribble strips and footswitch LED colors can now be customized from the Footswitch Assign, Controller Assign, and Command Center screens for any items assigned to a footswitch
- Processing blocks can be copied and pasted. Control-click (Win: Right-click) a block and select "Copy Block." Control/right-click the destination location or block you want to overwrite and select "Paste Block."
- Additional keyboard shortcuts:
H - Selects the Home tab
F - Selects the Footswitch Assign tab
C - Selects the Controller Assign tab
M - Selects the Command Center tab
G - Selects the Global EQ screen
P - Selects the Preset list
I - Selects the Impulse Responses list
A - Selects and cycles through Amp+Cab, Amp, and/or Preamp tonestacks
T - Tap Tempo
Space Bar - Toggles the currently selected block on and off
Tab - Toggles focus between the librarian and editor windows
Arrow Up/Down/Left/Right (Editor) - Selects the current block
Arrow Up/Down/Left/Right (Model List) - Navigates the model list
Arrow Up/Down (Librarian) - Navigates the preset or IR list
Enter/Return (Librarian) - Loads the selected preset
  • - Manually adjusts the most recently clicked slider
    Shift-[,][.], Shift-[-]
  • - Manually adjusts the most recently clicked slider faster
    Command-C (Win: Control-C) - Copies the current block
    Command-V (Win: Control-V) - Pastes the block
    Command-S (Win: Control-S) - Saves the preset
    Control-click (Win: Right-click) a slider - Allows for manually entering a value
    Command-click (Win: Control-click) a slider - Resets to default value
    OTHER IMPROVEMENTS
    - Input > Multi and Input > Variax now displays a Variax Volume slider
    - A light blue box surrounds either the librarian or editor panel, telling you which one is in focus; press Tab to toggle between them
    - Block selection is now synchronized between Helix and the Helix editor
    - A confirmation dialog now appears when attempting to clear all controllers
    - Added graphics for Input > USB 3/4, USB 5/6, and USB 7/8
    - Manually entering delay Time values is now accomplished in milliseconds, not seconds
    - The Helix firmware indicator in the upper left corner now reads "Firmware"
    BUG FIXES
    - Quickly moving an expression pedal assigned to many parameters can sometimes cause disconnection with Helix on Windows 7 - FIXED
    - Note sync was not assignable to a controller - FIXED
    - Importing a bundle while streaming audio could cause the Helix editor to disconnect - FIXED
    - Removing the last block on parallel path B would display a floating "None" block until a different block was selected - FIXED
    - Certain menu sliders could behave erratically when a footswitch had eight items assigned - FIXED
    - Moving blocks could automatically select EXP 2 if one of the blocks' parameters defaulted to EXP 1 - FIXED
    - Hardware and software could lose sync if a controller-assigned block was moved from Path 1A to 1B and back - FIXED
    - The Looper block's Footswitch Assign page displayed a momentary/latching slider - FIXED
    - A couple effects parameters were incorrect or missing - FIXED
    - Certain stereo delay models could display an incorrect Time parameter value - FIXED
    - Helix editor would sometimes not open immediately after closing Line 6 Updater - FIXED
    [/i]
Helix Firmware 2.01 Release Notes
Helix v2.01.0 is a firmware update that includes fixes, stability improvements, and optimizations. It is highly recommended that all Helix users perform this update!
IMPORTANT! YOU *MUST* FOLLOW THESE INSTRUCTIONS TO INSTALL 2.01!
2. Use your CURRENT EXISTING Helix application to back up all of your presets and IRs (if you want to keep them). If you're running Helix FW 1.12, your current Helix application version should be 1.12.
NOTE: You may want to back up individual Setlists so you can restore them to empty setlists without affecting the new 2.01 factory presets.
3. Quit the CURRENT EXISTING Helix editor application and download and install the NEW Helix editor application (2.01), available here: http://line6.com/software/ This also installs the newest version of Line 6 Updater (1.09).
5. Using the latest Line 6 Updater (1.09), update Helix/Helix Rack to the newest firmware (2.01). At the end of the update process, Helix/Helix Rack will reboot automatically and begin rebuilding presets. Wait for this process to complete.
6. If you're using Helix Control with Helix Rack, connect and power on Helix Control. The inspector will ask if you want to update its firmware. Press Knob 6 (OK). Wait for the update to finish.
YOU MUST RESET GLOBALS AND RESTORE PRESETS, OTHERWISE HELIX 2.01 WILL NOT WORK PROPERLY. DO IT. DO IT NOW:
7. To reset globals and restore presets, turn off Helix/Helix Rack.
HELIX FLOOR ONLY: While holding footswitches 9 and 10 (middle two switches on the bottom row), turn on Helix. Wait for the message "Will reset Globals and restore stock Presets, Setlists and IRs..." to appear and let go.
HELIX RACK ONLY: While holding knobs 5 and 6 below the screen, turn on Helix Rack. Wait for the message "Will reset Globals and restore stock Presets, Setlists and IRs..." to appear and let go.
8. Using the NEW Helix editor application (2.01), restore the user presets you backed up in step 2.
Improvements
- In addition to Tap Tempo, Snapshots and footswitches-as-controllers now also respect the Global Settings > Preferences > Tap Tempo Pitch setting
- 2.0 changed the default Guitar In-Z setting to "Auto" for new presets. Existing factory presets now also reflect this value
Bug Fixes
- Certain elaborate pre-2.0 presets with many controller assignments could sometimes fail to rebuild properly after updating from v1.x to v2.x firmware - FIXED
- Making parameter changes while changing snapshots can cause Amp+Cab parameters to display incorrect values - FIXED
- In rare cases, pressing the SAVE button twice in rapid succession could freeze Helix - FIXED
- After changing a Looper block to a Volume or Wah block, you could not change it back to a Looper block - FIXED
- In rare cases, navigating to a Merge > Mixer block on Path 2 could cause Helix to freeze - FIXED
- Turning the joystick to select a model and then pressing it before the model fully loads could sometimes result in the wrong item highlighted in the model list - FIXED
- In some cases, Multi and Guitar Input blocks' Guitar In-Z parameter would not be recalled correctly - FIXED
- Helix Rack only: The Tap Tempo LED could reengage after turning Global Settings > Displays > Tap Tempo LED off - FIXED
- Using a footswitch to very quickly toggle a parameter with only two values could sometimes not engage reliably - FIXED
- The new 2.0 pitch algorithms could behave strangely when playing certain chord forms - REVERTED
- Other minor bug fixes and optimizations
Known Issues
- Changing presets from the Editor while a block is picked up via the ACTION button can lead to instability
- Loading a new Snapshot from the Editor while Helix displays the Rename Snapshot page can lead to incorrect inspector items
Helix Editor v2.01 Release Notes
Helix v2.01.0 is a software update that includes fixes, stability improvements, and optimizations. It is highly recommended that all Helix users perform this update!
Improvements
Bug Fixes
- Switch LED parameter was not responsive from the Controller Assign screen - FIXED
- In some cases, Ext Amp and Note On message states were ignored when exported and then reimported - FIXED
- The Helix > Preferences > Stereo IR Import setting was not remembered - FIXED
- Engaging key commands while presets, setlists, or IRs were loading/exporting could result in instabilities - FIXED
Known Issues
- The Distortion > Bitcrusher Bit Depth parameter appears as "undefined"; continues to work properly from the hardware
http://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/page-1187
Bass in Zurich said: ↑
QuoteAlso interesting is that my flat response Audio Technica headphones (these) sound really, really, bad. The budget Sony (these) headphones sound a whole heap better.
Digital Igloo(Line-6) replied:
Those ATH-M50X's are 38 Ω? That could explain it. Low impedance headphones are designed to provide ample volume when listening to devices with relatively wimpy headphone amps, like mobile phones and iPods. Another user elsewhere expressed concern with his Beyer DT990s (which come in three variants—32 Ω, 250 Ω, and 600 Ω) and I'm willing to bet his are 32 Ω.
I'm actually surprised your Sonys sound any better, as they're even lower, at 24 Ω.
Helix's headphone amp is LOUD; it's designed to drive high-impedance studio headphones to stage volumes. Low impedance headphones distort way faster, fatigue your ears, and at a high enough volume, can damage your hearing. With Helix you could conceivably split the headphone output to two pairs of 200-300 Ω cans/IEMs and drive both over the sound of a drummer (and adjust respective levels via MIDI CC control of path output blocks). My band does this now.
Personally, I use Sennheiser HD600s (300 Ω), and before those, the HD580s (same). Also have a bunch of Sony 7506s around, but they're 63 Ω and harsh-sounding already, even with an iPod. I also keep a pair of Sennheiser HD280 Pros (64 Ω) at work and they're pretty boxy sounding, but if I can get a mix to sound good on them, it'll sound good anywhere. I treat them like wearable Yamaha NS10s, if those NS10s were powered by an Alesis RA100 instead of a Bryston. Wouldn't want to construct tones with them.
vtgearhead
On the subject of Hi-Z phones: Are there any other Signet (Audio-Technica) fans out there?  The TK-22s are my all-time favorite for reference use.  Just picked up a second lightly-used pair on eBay.
QuoteOn the subject of Hi-Z phones: Are there any other Signet (Audio-Technica) fans out there?  The TK-22s are my all-time favorite for reference use.  Just picked up a second lightly-used pair on eBay.
Same here - I'll let you know when mine arrive ;)
http://www.head-fi.org/t/248013/signet-tk22-disassembled-pics
QuoteAre there any other Signet (Audio-Technica) fans out there?  The TK-22s are my all-time favorite for reference use.  Just picked up a second lightly-used pair on eBay.
Mine finally arrived - they are in good shape and sound great for being 30+ years old!
96 ohms
vtgearhead
Quote from: Elantric on October 05, 2016, 03:13:46 PM
96 ohms
I really like mine for critical listening.  And, for extra credit, the ear cushions are made out of a cloth material that doesn't seem prone to degrading.
One thing is was wondering about the Helix: the display above the expression pedal always seems to read EXP1/EXP2 on every picture of the Helix. Is that really the only thing it can display?
http://www.thegearpage.net/board/index.php?threads/fractal-vs-helix-the-comparison-series-made-by-yours-truly.1757067/page-12
It seems to me there are quite a few buzz words thrown around, depending on your preference between the units.
If you don't like the Helix, the cabs are "harsh."
If you do like the Helix, it's more "raw" or "real."
If you don't like the Fractal, it's too "dark."
If you do like the Fractal, it's "smooth" or "pleasing."
And no one is wrong! It's all down to preference, and I think you guys are getting that.
From my experience in miking cabs and taking my own impulses, NEITHER unit sounds unrealistic or over-processed, and I think that's something I should've made more clear. Even though I'm skeptical of the ways the Helix's hybrid cabs were captured, I won't tell you that it's impossible to make an actual mic on an actual cab sound the way the Helix does, and I think that is an accomplishment on its own, truly. In the same way, the Fractal cabs are undoubtedly smoother or darker, but I don't think that's due to any sort of chicanery; I think that's due to careful mic choice and placement, which is something I prefer personally. Careful mic placement in this regard likely isn't possible with the capture of the Helix cabs, if my theory behind them is correct. But that's a whole other issue. End of the day, it really is all personal preference.
Cliff's direct thoughts are these (http://forum.fractalaudio.com/threads/fractal-irs.62159/page-3#post-772349)
"The factory IRs were hand-selected by me after auditioning thousands of OH and RW and other IRs. Some of the IRs are custom mixes of mine. My rule-of-thumb was to select as neutral sounding IRs as possible.
However, what I like may be much different than what others like. Some people complain the Axe-Fx sounds too bright. Others say it's not bright enough. It's a no-win situation. This is why I've been harping on capturing IRs. It's personal preference. Producers probably spend more time perfecting mic placement than anything else when getting guitar tones to tape. An IR is the same thing, it's capturing the mic and placement. Encouraging IR capture and sharing those IRs was a goal of mine but, alas, the community hasn't done much in that regard.
FWIW, I don't subscribe to "flavored" IRs (i.e. Warm or Fat or whatever). I do like the idea of using different preamps to capture the coloration of those preamps but I don't feel any additional EQ should be applied."
Helix® 2.20 is a firmware update for Helix and Helix Rack guitar processors that offers guitarists an additional suite of HX amp models, including new amps, cabinets and effects, with a special emphasis on models for bass players. The release will also feature a host of functional upgrades and a newly crafted set of impulse responses.
Included in the update are 6 amp models, 7 cabinet models, and 9 effect models. A total of 11 models are designed for bass players. Highlights in the release include models based on* the Pearce BC-1 bass preamp, a Darkglass® Electronics Microtubes® B7K Ultra bass preamp/overdrive/EQ pedal model, and Line 6 Badonk, an original Line 6 amp model inspired by the original high gain Big Bottom model.
Helix 2.20 also introduces the Line 6 Allure IR Pack, a free download of new speaker cabinet impulse responses created by Dan Boul of 65 Amps fame. Support for Variax® Workbench HD has been added, allowing Variax modeling guitars to communicate directly with Workbench HD editing software through Helix via USB. In addition, 2.20 adds the ability for Helix to send and receive MIDI Clock for synchronizing its tempo with DAW software and MIDI-based pedals.
vtgearhead
Quote from: Elantric on March 31, 2017, 12:26:37 AM
Helix® 2.20 is a firmware update for Helix and Helix Rack guitar processors that offers guitarists an additional Support for Variax® Workbench HD has been added, allowing Variax modeling guitars to communicate directly with Workbench HD editing software through Helix via USB. In addition, 2.20 adds the ability for Helix to send and receive MIDI Clock for synchronizing its tempo with DAW software and MIDI-based pedals.
A year and a half after introduction they finally add support for Variax Workbench.  Line 6 gets me scratching my head in amazement sometimes...
Frank Ritchotte
Quote from: snhirsch on March 31, 2017, 05:11:43 AM
We decided early on to leverage IdeaScale and let the customers decide what should go into Helix. That said there is a pretty robust roadmap of things that need to get into Helix for the longer term product plan that have to be done in a specific order. It may not look like it makes sense on the surface but there is always an underlying reason for the order in which we continue to add functionality.
Kevin M
Quote from: Frank Ritchotte on May 23, 2017, 07:21:51 AM
Does the current hardware support the roadmap, or will this involve a Helix 2.0?  Just curious!
Frank Ritchotte
Quote from: Kevin M on May 25, 2017, 02:24:12 PM
Yes. Helix has a bunch of future-proofing built in. There is stuff we have not yet turned on in there. The team did a great job of creating a long-term platform and forward thinking.
https://line6.com/software/index.html
HX Edit 2.30 Release Notes
New Amps (7)
- Voltage Queen, based on* the Victoria® Electro King
- Derailed Ingrid, based on* the Trainwreck Circuits® Express
- Brit Trem Nrm, based on* the normal channel of the Marshall® Plexi Tremolo 50
- Brit Trem Brt, based on* the bright channel of the Marshall® Plexi Tremolo 50
- Brit Trem Jump, based on* the normal and bright channel (jumped) of the Marshall® Plexi Tremolo 50
- Cartographer, based on* the Ben Adrian Cartographer
- Agua 51, based on* the Aguilar® DB751 bass amp
New Effects (7)
- Distortion > Kinky Boost (Mono, Stereo), based on* the Xotic® EP Booster
- Distortion > Thrifter Fuzz (Mono, Stereo), Line 6 Original
- Dynamics > Kinky Comp (Mono, Stereo), based on* the Xotic® SP Compressor
- Modulation > Bleat Chop Trem (Mono, Stereo), based on* the Lightfoot Labs© Goatkeeper
- Modulation > Double Take (Mono, Stereo), Line 6 Original doubler
- Delay > Cosmos Echo (Mono, Stereo), based on* the Roland® RE-201 Space Echo
- Volume/Pan > Stereo Width (Stereo), Line 6 Original utility to collapse stereo paths
* All product names are trademarks of their respective owners, which are in no way associated or affiliated with Line 6.
New Features
- Full State Backup and Restore—The all new HX Edit application can perform a full state backup and restore of your Helix, Helix Rack/Control, and Helix LT presets, IRs, and global settings. IMPORTANT! You MUST be running Helix firmware 2.20 or higher to use full state backup and restore! From the File pulldown menu, select "Create Backup..." Click [Create Backup] to confirm. To restore from a backup, from the File pulldown menu, select "Restore From Backup..." From the Backup File pulldown, select the desired backup and click [Restore Backup]. You may choose to restore any combination of 8 setlists, IRs (including the index order), and/or Global Settings
Show/Hide PRESETS/IMPULSES List—Click the icon to the left of the preset name to show or hide the PRESETS/IMPULSES list
Known Issues
- In rare cases, moving a block from Path A to Path B can result in the Split block being created in the wrong position
- In rare cases, importing an IR file into the current "Empty" slot of an Impulse Response block can cause audio output to mute Workaround: Drag impulse response files directly into the IMPULSES list
https://www.gearnews.com/namm-2018-line-6s-helix-2-5-update-imminent-huge/
NAMM 2018: Line 6's Helix 2.5 update imminent – and it's huge.
Friedman BE-100 and MESA Lonestar added to Helix!
Line 6 Helix 2.5 Update announced
Line 6 Helix 2.5 Update announced and it is massive!  ·  Source: Line 6
The long-anticipated Line 6 Helix 2.5 update has been announced and it is massive, including a shedload of legacy effects and two cool boutique amp emulations for you to drool over as well.
This is a long list of effects and also a couple of sweet new boutique valve amp models based on the Mesa Lonestar and the Friedman BE and HBE of channels the BE-100 amp head.
Effects galore!
It isn't that long since we had the 2.3 update late last year, just in time for Christmas, but the 2.5 update looks to eclipse that with an insanely long list of new reverbs, delays, filters, modulations and distortions.
The update is due soon according to Line 6's website and it is one we at gearnews cannot wait to try out.
Make sure you scroll right to the bottom of this article and check out some of the new reverbs being demoed by Alex.Guitars on his YouTube channel, they sound pretty glorious and well worth the wait.
I'll keep you all informed and let you know exactly when 2.5 officially drops, so for now take a look at the official Line 6 list and start drooling...
New Amps (2)
Cali Texas Ch2, based on* the drive channel of the MESA/Boogie® Lonestar (Ch1 coming later)
Placater Dirty, based on* the BE/HBE channel of the Friedman BE-100 (Clean channel coming later)
New HX Effects (6)
Delay > Multi Pass (Mono, Stereo), Line 6 Original bandpass-filtered multitap delay
Reverb > Glitz (Mono, Stereo), Line 6 Original
Reverb > Ganymede (Mono, Stereo), Line 6 Original
Reverb > Searchlights (Mono, Stereo), Line 6 Original
Reverb > Plateaux (Mono, Stereo), Line 6 Original
Reverb > Double Tank (Mono, Stereo), Line 6 Original
New Legacy Effects Models (77)
Helix Floor, Rack/Control, and LT now include a library of effects from M13, M9, M5, DL4, DM4, FM4, and MM4. These appear in a new "Legacy" subcategory in the model list.
Distortion > Tube Drive
Distortion > Screamer
Distortion > Overdrive
Distortion > Classic Dist
Distortion > Heavy Dist
Distortion > Colordrive
Distortion > Buzz Saw
Distortion > Facial Fuzz
Distortion > Jumbo Fuzz
Distortion > Fuzz Pi
Distortion > Jet Fuzz
Distortion > Line 6 Drive
Distortion > Line 6 Distortion
Distortion > Sub Oct Fuzz
Distortion > Octave Fuzz
Dynamics > Tube Comp
Dynamics > Red Comp
Dynamics > Blue Comp
Dynamics > Blue Comp Treb
Dynamics > Vetta Comp
Dynamics > Vetta Juice
Dynamics > Boost Comp
Modulation > Pattern Tremolo
Modulation > Panner
Modulation > Bias Tremolo
Modulation > Opto Tremolo
Modulation > Script Phase
Modulation > Panned Phaser
Modulation > Barberpole
Modulation > Dual Phaser
Modulation > U-Vibe
Modulation > Phaser
Modulation > Pitch Vibrato
Modulation > Dimension
Modulation > Analog Chorus
Modulation > Tri Chorus
Modulation > Analog Flanger
Modulation > Jet Flanger
Modulation > AC Flanger
Modulation > 80A Flanger
Modulation > Frequency Shift
Modulation > Ring Modulator
Modulation > Rotary Drum
Modulation > Rotary Drm/Horn
Delay > Ping Pong
Delay > Dynamic
Delay > Stereo
Delay > Digital
Delay > Dig w/ Mod
Delay > Reverse
Delay > Lo Res
Delay > Tube Echo
Delay > Tape Echo
Delay > Sweep Echo
Delay > Echo Platter
Delay > Analog Echo
Delay > Analog w/ Mod
Delay > Auto-Volume Echo
Delay > Multi-Head
Pitch/Synth > Bass Octaver
Pitch/Synth > Smart Harmony
Pitch/Synth > Octi Synth
Pitch/Synth > Synth O Matic
Pitch/Synth > Attack Synth
Pitch/Synth > Synth String
Pitch/Synth > Growler
Filter > Voice Box
Filter > V Tron
Filter > Q Filter
Filter > Seeker
Filter > Obi Wah
Filter > Tron Up
Filter > Tron Down
Filter > Throbber
Filter > Slow Filter
Filter > Spin Cycle
Filter > Comet Trails
Improvements/Changes
If a Snapshot has been given a custom switch colour, that switch ring now displays a dim colour when not active
12 of Helix's 17 reverbs originally appeared in M-Class processors and Verbzilla. As such, they've been moved into the new "Legacy" subcategory within the Reverb category
Helix's tempo no longer responds to pressing TAP at tempi lower than 40.0 BPM (Beats Per Minute). This is to ensure that multiple fast tap entries are recognized properly, as previously, they could be seen as one really slow tap entry. You may still manually select a tempo all the way down to 20.0 BPM and your presets can still be saved with tempi down to 20.0 BPM—just touch TAP and turn Knob 6 (BPM)
