GP-10 Normal Amp Front End Bank
Started by jwhitcomb3, June 20, 2015, 08:46:09 AM
jwhitcomb3
Here is a bank of presets I made for using the GP-10 as a front end to my tube amp. There is no COSM amp modeling used.
For the most part, I used these presets to try out the various COSM overdrive/distortion pedal models in front of my amp. The patches are named "AFE XXXXX" with AFE = "Amp Front End" and "XXXXX" = the OD/Dist pedal. There are also a couple of compressors here.
Ctl1 Tap Tempo
Ctl2 OD Solo Switch
Ctl3 FX toggle              (If you don't have a Boss FS-6 or FS-7, get one!  ;) )
Ctl4 Chorus toggle
ExpOff Delay level
ExpSw Wah Toggle
ExpOn Wah
There are also COSM guitars enabled for each preset, which are simply ignored if you use the normal input (disable them if you like). I use the switch on my RR Strat to switch between COSM, Normal and Blend. The GK vol controls the modeling volume and S1/S2 are pickup select up/down.
I have found it useful to set the Patch Extent parameter around the AFE presets, because they are much lower output and accidentally selecting a non-AFE patch can be startling.
