GR-55 - Wobble Bass
Started by Chernodedov, May 11, 2013, 02:20:40 AM
Chernodedov
can someone clocked cool Wobble? share your patches!).
Welcome to the group Chernodedov!  :)
Chernodedov
Thank .). g-55 have a couple of months ..while I twist and I can not find normal Wobble .. although found a lot of other  cool sounds .). .. general:-still in search of bass Wobble  ???
Pchel
aka wobble bass (no time)  ;D ;D ;D      BASS MODE      for PEDAL
fuzzfactory
making a simple wobble is easy
pcm synth on1 sine wave
pcm synth two basic square wave
set the LFO 1 on synth two to modulate the filter cutoff of the square wave.
assign  the exp. pedal to control the rate of LFO1
done.... 8)
MachineGunFunk
#5
got some cool dubstep-ish sounds I want to get the full transformer sound working on some patches. Im a new gr 55 user and im just begining to understand what this thing does!!
Spreading Banjo Awareness and positivity
compulsive
First, greetings to all, I'm happy to be in this community!
Quote from: fuzzfactory on June 28, 2013, 02:08:25 AM
I tried to do the woobble synth whit the istruction below. playing with cutoff and resonance comes something cool!
but the strange thing is that playing with the expression pedal the LFO rate increases strangely.
slow, fast, very fast and then again slowly and progressively up to the maximum rate ..
really weird.
imerkat
I have a patch i share called "DeceptiCon" that uses the Ring Mod to create the Wobble or Growl on this thread:
https://www.vguitarforums.com/smf/index.php?topic=15261.msg109672#msg109672
compulsive
