VG-99 - fr8hop - wonky double tracked blues-ish
Started by kloniwotski, February 09, 2009, 04:23:53 PM
kloniwotski
PATCH NAME: fr8hop
Version: 0.1a
Category: Others
Style: Blues
Description:
This patch rings a variation on Dave Coffin's Sarod Duet patch
( https://www.vguitarforums.com/smf/index.php/topic,1075.0.html )
which uses input level to bend the B channel, the note returning to normal pitch as the volume fades.
I've toned down the amount of bend on channel B to something more in the range of double tracking, but then used a different method to achieve a similar detune effect on the other channel - this is done in assign 2, by controling the delay time on channel A's Warp Echo effect. With the parameters used, this seems to give a sudden rise in pitch up to the played note when input is moderately high, a bit like a bottleneck rushing up to the right pitch.
In the accompanying mp3, you hear me messing with a couple of bluesy riffs using this patch (please excuse the playing, I'm emphatically not a blues purist!). In the first bit you can hear the note-bending on the chord above the chunk-a-chunk part, which sounds a bit like string-bending or a bottleneck, but is just fretted normally. The following section is in there for the "wonky double tracked" sound.
The EQ and tone could be improved a fair bit, I imagine - any further revisions would be welcome!
(By varying the delay parameters for channel A and the assign 2 parameters, some very whacky noises indeed are possible!)
FileType: mid
maxdaddy
