Fishman TriplePlay Tuner Calibration Question
Started by jorgestelling, August 29, 2016, 06:37:36 PM
jorgestelling
Does anyone know the tuner calibration range for the Fishman TriplePlay software ???? I'm specifically trying to find out if it goes down to 432 hz.
Thanks!
Good question...   I'm pretty sure it's stuck at A440...
FishmanSQA
Quote from: jorgestelling on August 29, 2016, 06:37:36 PM
Thanks!
If you use the D Pad within the Tripleplay app to navigate to Global Parameters>Tune Base, you can adjust the parameters from there.
Hope this helps!
Best,
Sara
QuoteIf you use the D Pad within the Tripleplay app to navigate to Global Parameters>Tune Base, you can adjust the parameters from there.
Does it allow to change from
A = 440hz
to
A= 432hz ?
Did a quick search & found this old post...
QuoteAfter some experimentation, I confirmed that TUNE BASE allows you to do non A-440 tuning.  It appears to be about 4 units per Hz., e.g., to tune A-444, you'd set TUNE BASE to 16.
Clearly I've forgotten more than I remember... ::)
what's the available range?
Does it accept "Tunebase = -32"" to achieve A=432Hz ?
#6
To answer the OP's question - I think a Tune Base of -32 will take you to A=432.   Let me know how this works out!
Sounded like a fun math problem for a Saturday morning...  The following chart is based on the assumption that they are using the standard MIDI "cents", which is 1/100 of a semitone.
Note that as you change Tune Base, the FTP smartly sends out the MIDI Fine Tuning RPN to make the corresponding change in your hardware synthesizer, in order for you to stay in tune with your synth.  Warning:  I do not know of any soft synths that support the standard MIDI Fine Tuning RPN!
Bottom line:  4 clicks per Hz...
I'm pretty sure this is it:
Tune                MIDI Fine-tune RPN
Base   Freq                CC#6   CC#38
-100   415.3046976   0   0      (Ab when A=440)
-99   415.5446563   0   96
-98   415.7847536   1   32
-97   416.0249897   2   0
-96   416.2653646   2   64
-95   416.5058783   3   32
-94   416.746531   3   96
-93   416.9873228   4   64
-92   417.2282537   5   0
-91   417.4693238   5   96
-90   417.7105332   6   64
-89   417.951882   7   0
-88   418.1933702   7   96
-87   418.4349979   8   32
-86   418.6767653   9   0
-85   418.9186723   9   64
-84   419.1607191   10   32
-83   419.4029058   11   0
-82   419.6452324   11   64
-81   419.887699   12   32
-80   420.1303057   12   96
-79   420.3730526   13   64
-78   420.6159397   14   0
-77   420.8589672   14   96
-76   421.1021351   15   32
-75   421.3454435   16   0
-74   421.5888925   16   96
-73   421.8324821   17   32
-72   422.0762125   18   0
-71   422.3200837   18   64
-70   422.5640958   19   32
-69   422.8082489   19   96
-68   423.0525431   20   64
-67   423.2969784   21   0
-66   423.541555   21   96
-65   423.7862728   22   64
-64   424.0311321   23   0
-63   424.2761328   23   96
-62   424.5212751   24   32
-61   424.7665591   25   0
-60   425.0119847   25   64
-59   425.2575522   26   32
-58   425.5032615   27   0
-57   425.7491129   27   64
-56   425.9951062   28   32
-55   426.2412417   28   96
-54   426.4875195   29   64
-53   426.7339395   30   0
-52   426.9805019   30   96
-51   427.2272067   31   32
-50   427.4740541   32   0
-49   427.7210441   32   96
-48   427.9681769   33   32
-47   428.2154524   34   0
-46   428.4628708   34   64
-45   428.7104321   35   32
-44   428.9581365   35   96
-43   429.205984   36   64
-42   429.4539747   37   0
-41   429.7021087   37   96
-40   429.9503861   38   64
-39   430.1988069   39   0
-38   430.4473713   39   96
-37   430.6960793   40   32
-36   430.9449309   41   0
-35   431.1939264   41   64
-34   431.4430657   42   32
-33   431.692349   43   0
-32   431.9417763   43   64      A=432
-31   432.1913477   44   32
-30   432.4410634   44   96
-29   432.6909233   45   64
-28   432.9409275   46   0
-27   433.1910763   46   96
-26   433.4413695   47   32
-25   433.6918074   48   0
-24   433.94239   48   96
-23   434.1931173   49   32
-22   434.4439896   50   0
-21   434.6950067   50   64
-20   434.946169   51   32
-19   435.1974763   51   96
-18   435.4489288   52   64
-17   435.7005266   53   0
-16   435.9522698   53   96
-15   436.2041585   54   64
-14   436.4561927   55   0
-13   436.7083725   55   96
-12   436.960698   56   32
-11   437.2131693   57   0
-10   437.4657865   57   64
-9   437.7185496   58   32
-8   437.9714588   59   0
-7   438.2245141   59   64
-6   438.4777156   60   32
-5   438.7310635   60   96
-4   438.9845577   61   64
-3   439.2381983   62   0
-2   439.4919856   62   96
-1   439.7459194   63   32
0   440                   64   0      A
1   440.2542274   64   96
2   440.5086017   65   32
3   440.7631229   66   0
4   441.0177912   66   64
5   441.2726067   67   32
6   441.5275693   67   96
7   441.7826793   68   64
8   442.0379367   69   0      A=442
9   442.2933416   69   96
10   442.5488941   70   64
11   442.8045942   71   0
12   443.060442   71   96
13   443.3164377   72   32
14   443.5725813   73   0
15   443.8288729   73   64
16   444.0853125   74   32
17   444.3419004   75   0
18   444.5986365   75   64
19   444.8555209   76   32
20   445.1125537   76   96
21   445.3697351   77   64
22   445.6270651   78   0
23   445.8845437   78   96
24   446.1421711   79   32
25   446.3999474   80   0
26   446.6578726   80   96
27   446.9159468   81   32
28   447.1741702   82   0
29   447.4325427   82   64
30   447.6910645   83   32
31   447.9497357   83   96
32   448.2085564   84   64
33   448.4675266   85   0
34   448.7266464   85   96
35   448.985916   86   64
36   449.2453353   87   0
37   449.5049046   87   96
38   449.7646238   88   32
39   450.024493   89   0
40   450.2845125   89   64
41   450.5446821   90   32
42   450.8050021   91   0
43   451.0654725   91   64
44   451.3260934   92   32
45   451.5868649   92   96
46   451.8477871   93   64
47   452.10886   94   0
48   452.3700837   94   96
49   452.6314584   95   32
50   452.8929841   96   0
51   453.1546609   96   96
52   453.4164889   97   32
53   453.6784682   98   0
54   453.9405989   98   64
55   454.202881   99   32
56   454.4653147   99   96
57   454.7279   100   64
58   454.990637   101   0
59   455.2535258   101   96
60   455.5165665   102   64
61   455.7797592   103   0
62   456.0431039   103   96
63   456.3066009   104   32
64   456.57025   105   0
65   456.8340515   105   64
66   457.0980055   106   32
67   457.3621119   107   0
68   457.6263709   107   64
69   457.8907826   108   32
70   458.1553471   108   96
71   458.4200645   109   64
72   458.6849348   110   0
73   458.9499581   110   96
74   459.2151346   111   32
75   459.4804643   112   0
76   459.7459473   112   96
77   460.0115836   113   32
78   460.2773735   114   0
79   460.5433169   114   64
80   460.809414   115   32
81   461.0756649   115   96
82   461.3420696   116   64
83   461.6086282   117   0
84   461.8753408   117   96
85   462.1422075   118   64
86   462.4092284   119   0
87   462.6764036   119   96
88   462.9437332   120   32
89   463.2112172   121   0
90   463.4788558   121   64
91   463.746649   122   32
92   464.014597   123   0
93   464.2826998   123   64
94   464.5509574   124   32
95   464.8193701   124   96
96   465.0879378   125   64
97   465.3566608   126   0
98   465.625539   126   96
99   465.8945725   127   32
100   466.1637615   128   0      (A# when A=440)
Quote-32   431.9339795   43   64      A=432
Ah but the A=432hz advocates who seek a true  A=432hz will be disappointed with A=431.9339795Hz and claim they hear and feel the difference between A=432Hz vs A=431.9339795Hz
As they blame big government who conspired to eliminate A=432Hz and its natural healing properties for the masses.
Quote"This unnatural standard tuning frequency (440 hz), removed from the symmetry of sacred vibrations and overtones, has declared war on the subconscious mind of Western Man."
http://humansarefree.com/2011/03/does-conspiracy-extend-to-musical-scale.html
http://humansarefree.com/2011/05/432-hz-vs-440-hz-documentary.html
I only worry about being in tune with the Acoustic Piano player
Or tune to Eb if playing with Sax and horns
#8
For all the fancy logarithmic math, my initial quick observation that 4 clicks per Hz works.       ::)
(...relative to A440)
