Roland UM-ONE MKII USB MIDI Cable
Started by residentorca, January 08, 2016, 10:43:00 AM
residentorca
http://www.roland.com/products/um-one_mk2/
http://www.roland.com/products/um-one_mk2/downloads/
* One-in/one-out MIDI interface with high-performance FPT processing
* Compatible with Mac and Windows operating systems, and now with iOS on the iPad via the Apple iPad Camera Connection Kit
* Super-compact, affordable, and easy to use
* Data indicators for both MIDI input and output
* Conveniently integrated USB and MIDI cables
* USB bus-powered operation
USB Drivers for the UM-ONE mk2:
Owners Manual
http://cdn.roland.com/assets/media/pdf/UM-ONEMK2_e03_W.pdf
Addendum
http://cdn.roland.com/assets/media/pdf/UM-ONEmk2_l_iPad_e02_W.pdf
Godin LGX-T
Roland VG-8
Boss GP-10
UM-ONE Driver Ver.1.0.0 for Windows® 7 32-bit Edition / 64-bit Edition
(Note)
In no event shall Roland Corporation ("Roland") be liable to end-users for any damages whatsoever, including but not limited to financial damages for loss of business profits or business information arising from the use of, or inability to use this product. The foregoing provision is effective even if Roland has been advised of the possibility of such damages.
*   All files and other material contained in this folder are copyrighted by the Roland. Any alteration, modification, duplication, distribution, or reproduction of this material is prohibited. Additionally, Roland reserves the right to make changes to these programs and files without prior notice.
*   Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
*   All product names mentioned in this document are trademarks or registered trademarks of their respective owners.
About this driver
This is the UM-ONE driver for Microsoft® Windows® 7 32-bit Edition / 64-bit Edition.
System requirements
This driver has the following requirements.
Operating System
Microsoft® Windows® 7 64-bit Edition
Computer
A computer with a USB connector that supports USB Specification Revision 1.1 or higher
*   This driver cannot be used in a virtual Windows environment, such as Windows XP Mode (Virtual Windows XP) or Virtual PC.
*   Macintosh computers running Microsoft Windows are not supported.
Caution when using the Windows 7 64-bit Edition
In order to use this product with the 64-bit Edition of Windows 7, please read and understand the following points. You must also take into account the compatibility of each product you will be using.
In order to use the 64-bit Edition of Windows 7, you must use 64-bit drivers; not only for this product, but also for all hardware you're using with your computer.
This driver has been tested on several computer systems, but please understand that we cannot guarantee it will operate on your particular computer.
Cautions and Limitations
Sound interruption or other less-than-perfect outcomes may be experienced if your computer's performance and specifications are somewhat inadequate. The types of applications you use and the way in which you use them can also influence the experience you receive.
On some computers, the driver does not load correctly if the UM-ONE is already connected when Windows is started up. As a result, it will not be possible to use the UM-ONE via USB. If this occurs, wait until after Windows has started to connect the UM-ONE.
If the UM-ONE does not work correctly after resuming from Sleep mode, you should exit all applications that use the UM-ONE, and then disconnect the USB cable of the UM-ONE and reconnect it.
If the USB cable is disconnected and reconnected while the UM-ONE is in use, it may stop operating correctly. If this occurs, after resuming, you should exit all applications that use the UM-ONE, and disconnect/reconnect the USB cable of the UM-ONE.
If your computer was experiencing a heavy processing load, such as when accessing a CD-ROM Drive or network while the UM-ONE was being used, the UM-ONE may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again. If you are still unable to play back or record, quit all programs that are using the UM-ONE, then disconnect the USB cable of the UM-ONE and reconnect it.
Installation
*   To reinstall or update the driver, refer to "To reinstall."
1 ) Start up Windows with all USB cables disconnected. (except for keyboard and mouse)
2 ) Exit all applications before you begin the installation.
3 ) Double-click the Setup icon.
*   If a message informs you that "Driver installation must be performed by an administrator," you must log on to Windows as a user whose Account Type is Administrator, and then perform the installation.
4 ) A confirmation screen regarding User Account Control will appear, click [Yes].
5 ) The message "UM-ONE Driver will be installed on your computer. ---" will appear. Click [Next].
*   If any other message appears, follow the directions of the message.
6 ) Click [Next] to begin installation.
7 ) If a dialog box regarding Windows Security appears, click [Install].
8 ) The message "Ready to install the driver. ---" will appear.
9 ) Use a USB cable to connect the UM-ONE to your computer.
The driver will be installed automatically.
10 ) When the "Installation has been completed." message appears, installation has been completed.
Click [Close] to close the "Driver Setup" dialog box.
11 ) If the "System Settings Change" dialog box appears, click [Yes] to restart Windows.
12 ) Refer to "Before you begin," and make the necessary settings for using the UM-ONE. You won't be able to use the UM-ONE unless you make these settings.
*   If you are unable to use the UM-ONE after connecting it, it's possible that a problem has occurred. Refer to "Troubleshooting."
Before you begin
Input/output device settings for your application
In the application(s) that you intend to use, specify the MIDI device they are to use. (For details on this setting, refer to the owner's manual for your application.)
*   If you are unable to select the UM-ONE device, a problem may have occurred. Refer to "Troubleshooting."
MIDI input/output device
*   In the Windows Media Player, the MIDI input/output device of UM-ONE cannot be used.
Please select the following device in your MIDI compatible application.
[MIDI OUT devices]
UM-ONE
[MIDI IN devices]
UM-ONE
To change the settings
To change or verify settings
When changing driver settings, always make sure to first quit all applications using the UM-ONE. This is unnecessary when only checking the settings.
Open the "Control Panel," switch "View by:" to the icon view (Large icons or Small icons), and then click "UM-ONE."
The "UM-ONE Driver Settings" dialog box will appear.
To modify the settings, make the changes and click [OK]. To simply check the settings, be sure to click [Cancel] after viewing the settings.
*   For details on the setting items, refer to "About the items in the Settings dialog box."
The "Light Load" check box
Normally, you should leave this check box cleared.
*   The modified setting will take effect after the USB cable of the UM-ONE is disconnected and reconnected.
"Show README" button
This button displays the README file (this document).
Information
This field shows the driver version.
To reinstall
Delete the driver as described in "To uninstall."
*   When you uninstall, the settings of the Driver Settings dialog box will be initialized. For details on the setting items, refer to "About the items in the Settings dialog box."
Install the driver as described in "Installation."
To uninstall
Exit all applications before you begin the uninstallation.
Open "Control Panel" and click "Uninstall a program."
*   If the icon view is selected for the Control Panel, click "Programs and Features."
In the list, choose "UM-ONE Driver", and click "Uninstall/Change."
If a dialog box regarding User Account Control appears, click [Yes].
*   If you are asked to enter the password for an administrative account, log on to Windows as a user whose Account Type is Administrator, and then perform the uninstallation.
The display will indicate "The installed UM-ONE Driver will be uninstalled." and click the [OK].
When the message "Uninstallation was completed." is displayed, click [OK] to restart Windows.
Troubleshooting
Cannot install/uninstall the driver
Are you logged onto Windows with the appropriate user rights?
You must log on to Windows as a user whose Account Type is Administrator.
*   For more information regarding this, consult your computer system administrator.
Cannot select/use the UM-ONE device
Was the driver installed correctly?
If you can't use the UM-ONE even though you've installed the driver, the driver might not be installed correctly. Use the procedure described in "To reinstall" to reinstall the driver.
Could the UM-ONE be in use by other software?
Exit all applications that are using the UM-ONE, and disconnect/reconnect the USB cable of the UM-ONE.
If this does not solve the problem, use the procedure described in "To reinstall" to reinstall the driver.
Is the UM-ONE MIDI device name displayed?
If the device name is not displayed, exit all applications that are using the UM-ONE, and disconnect/reconnect the USB cable of the UM-ONE.
Did the computer enter a Sleep mode while the UM-ONE was connected?
Was the USB cable disconnected and reconnected while the UM-ONE was being used?
If the USB cable is disconnected and reconnected while the UM-ONE is in use, it may no longer operate correctly. If this occurs, exit all applications that are using the UM-ONE, and disconnect/reconnect the USB cable of the UM-ONE.
On some computers, if the UM-ONE is connected while Windows starts up, the driver will not be loaded correctly, and it will not be possible to use the UM-ONE via USB.
If this occurs, start up Windows before you connect the UM-ONE.
A number such as "2-" is now displayed at the beginning of the device name
Could you have connected the UM-ONE to a different USB port?
If you connect the UM-ONE to a different USB port, the operating system may automatically add a number to the beginning of the device name.
Even if this occurs, it will not cause any problems with the operation of the UM-ONE.
*   If you want to restore the device name that does not have this added number, connect the UM-ONE to the same USB port as when you installed it, or reinstall the driver as described in "To reinstall."
No sound is heard; cannot playback or record
Did you make settings as described in "Before you begin" so that the UM-ONE driver could be used?
The UM-ONE cannot be used unless you make these settings. Refer to the sections on "Before you begin."
Could you have entered Sleep mode during playback or recording?
During playback or recording, did you disconnect and reconnect the USB cable?
If you disconnect and reconnect the USB cable during playback or recording, the UM-ONE will no longer be able to play back or record. Stop playback or recording, and then start playback or recording once again. If you are still unable to play back or record, quit all programs that are using the UM-ONE, then disconnect/reconnect the USB cable of the UM-ONE.
Part of the playback is wrong: e.g., notes are broken off prematurely, or some notes are lost
Problems may be solved by making the settings shown below.
Try updating the driver of your display adaptor
You may be able to eliminate clicks and pops by updating the driver for the display adaptor installed in your computer.
Windows Update / Microsoft Update
You may be able to solve the problem by updating your system with "Windows Update" or "Microsoft Update" provided by Microsoft.
Check the power management settings
Open "Control Panel," click "System and Security," and then click "Power Options."
*   If the icon view is selected for the Control Panel, click "Power Options."
In "Select a power plan," choose "High performance."
*   If the "High performance" plan is not shown, click "Show additional plans."
In the High performance area, click "Change plan settings."
Click "Change advanced power settings."
In the Advanced Settings, click the "+" symbol for "Hard Disk," and click the "+"symbol for "Turn off hard disk after" to open it.
Click "Setting (Minutes)," and click the down arrow to change the setting to "Never."
Click [OK] to close the Power Options window.
Close the "Edit Plan Settings" screen.
"Performance Options" settings of System Properties
Open "Control Panel," click "System and Security," and then click "System."
*   If the icon view is selected for the Control Panel, click "System."
At the left, click "Advanced system settings."
*   If you are asked to enter the password of an Administrator account, log on to Windows as a user whose Account Type is Administrator, then perform the settings again.
Click [Settings] of the Performance section, and then click the [Advanced] tab.
Select "Background services," and click [OK].
Click [OK] to close "System Properties."
Such problems may be solved if you check the "Light Load" check box in the Driver Settings dialog box.
If you wish to modify or verify the settings, use the procedure described in "To change the settings."
*   The modified setting will take effect after the USB cable of the UM-ONE is disconnected and reconnected. Unless you experience problems, use the unchecked (initial) setting.
Roland UM ONE MKII USB Driver for Vista installation instructions in the README.HTM file contained in the Roland UM ONE MKII USB Driver for Vista zip file (umone_visd_v100.zip)
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=16981.0;attach=14166
Roland UM-ONE MKII USB Driver details for Win10 (PDF)
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=16981.0;attach=19259
https://www.roland.com/global/support/by_product/um-one_mk2/updates_drivers/09a08c60-40fd-46d6-b2d4-47f1781dbc2e/
https://www.roland.com/us/support/knowledge_base/?product=UM-ONE+mk2
https://www.roland.com/us/support/knowledge_base/214330803/
UM-ONE MK2: CONNECTING TO A WINDOWS 10 COMPUTER
Back to Results
Tags: USB, UM-ONE MK2
Windows 10 has changed the way USB drivers are installed - in most cases the driver will now be installed automatically, so there is no need for the user to download and install a driver manually.
Because of this, you should just need to connect the UM-ONE MK2 to a USB port on a Windows 10 computer and the driver will be automatically installed (this can take 10-20 seconds).
There are a few things to be aware of:
The UM-ONE MK2 can connect to a computer in two different ways, depending on the setting of the small switch labelled "COMP" or "TAB."
COMP: This mode requires that a Roland driver be installed on your computer for the UM-ONE MK2 to connect. Using this option you can take advantage of Roland's FPT processing technology which provides for faster MIDI processing speeds.
TAB: This mode allows the UM-ONE MK2 to use the USB MIDI Driver that is built into your computer's operating system, and does not require that a Roland driver be installed. This mode is often called "Class Compliant."
Both of these options will work with Windows 10.
Once you have connect the UM-ONE MK2, the small LED labelled "USB" should light up indicating that the interface is receiving power and communicating with the computer.
You can also check on your computer to confirm that the UM-ONE MK2 is connected correctly - open the Device Manager and confirm that the UM-ONE MK2 is listed under "Sound, video, and game controllers."
Once the driver is installed and the USB light on the interface is lit, you should then be ready to use the UM-ONE MK2 with your music applications.
