Gr55 as midi to dmx light controller
Started by sean_b, November 04, 2015, 02:06:52 AM
sean_b
Hi, as the subject says, can the gr55 be used as a midi to dmx light controller. I know keyboards can do it, it would be cool if the lights were in sync with the guitar parts.
Cheers
Sean
Yes, it sure can.
Make sure the GR-55 guitar to midi output is 'on' in the system midi settings.
My choice of DMX software is FreeStyler,
http://www.freestylerdmx.be/
I use a DIY midi cc# foot controller to control lighting scenes, each scene uses 128 DMX channels.
It can be setup to respond to midi note data too.
sean_b
Cheers gumtown,
Have you or anyone else used the iPad app of freestyler? If I could the iPad it would easier than bringing a laptop.
Regards
Sean
sean_b
Hey gumtown, how do you set up the chain from gr55 back lights, ie connections and the likes
Cheers
Sean
It is all here
https://www.vguitarforums.com/smf/index.php?topic=11161.msg82356#msg82356
a D.I.Y USB midi/DMX pedal,
The pedal buttons each send a midi cc# message from a PIC micro controller to a USB midi adapter, to a USB mini hub, to the windows laptop running FreeStyler.
Freestyler is setup to receive midi and select a certain lighting scene associated with the midi cc# command.
Freestyler sends the DMX data via USB back to the DIY controller, through the USB hub, to a USB/RS422 adapter (FTDI chipset), which is connected to a wireless DMX transmitter, the DMX is received by all the wireless lighting fixtures, each with a unique DMX address.
FreeStyler can be setup to work with any midi data, just select a function, set midi learn mode, and send the midi message to work with.
