Livid Instruments Guitar Wing
Started by jassy, January 22, 2014, 11:52:31 AM
jassy
Not sure if this project has been mentioned here (tried to search with no results).
At least to me it seems very interesting, its a thing that Im thinking about long time (even I considered to make my own with some engineer friends although never advanced very much really) has it would enhance greatly the control over effects and synths directly from the guitar.
Maybe it has to much controllers on board and the design and layout is not the most beautiful that I have ever seen. To be honest I'm not sure I want to have something so big and bulky on my guitar and I think it can be a handicap for many guitarist which may seen it too obtrusive.
There is a project fund running here: http://www.kickstarter.com/projects/livid/guitar-wing-wireless-control-surface-for-guitar-an
With luck we will resurrect a similar project
VGuitar Wireless guitar Midi Controller project
https://www.vguitarforums.com/smf/index.php?topic=7984.0
Macciza
Hey everyone,
Thought this looked cool, so I got one on order.
Check out the Livid Instruments Guitar Wing wireless controller for guitars.
More info at guitarwing.com or go to Kickstarter project.  . .
Can't wait . . .
'70s Strat, Brian Moore iM, VG-8, VG-99, FC-300, VL-70m, StringPort, SoftStep, Sentient6, iMac QC i7 27".
vanceg
I just went and supported their kickstarter.  Livid are good folks and they have proven that they can come out with quality product.
Y'all should consider supporting too!
https://www.kickstarter.com/projects/livid/guitar-wing-wireless-control-surface-for-guitar-an
GovernorSilver
#5
I emailed Livid to see if Guitar Wing would work with an iPad without an intermediary computer.  They said that it would via Bluethooth connection to the USB MIDI dongle and Camera Connector.  They also said that they do have plans for an iPad app that would enable direct Guitar Wing<->iPad connection over Bluetooth.
My laptop is nearing end-of-life, so I'm likely to use Guitar Wing with an iPad effects app like Swoopster, Turnado, or maybe even Loopy.  Triggering sequencers or even more oddball apps like Lemur is also a possibility.
EDIT:  I see they have updated their Kickstarter page with a mention of iConnectMIDI for usage with hardware MIDI gear (no computer required).
abhijitnath
I assume this will not work correctly with left handed guitars because of the layout? I wonder if upper bout placement would make sense ergonomically.
carlb
Morningstar MC8 & MC6
QSC CP8 powered speaker
supernicd
Interesting, had not seen this before.  Seems like this + GR-55 + class compliant USB to MIDI cable might open the GR-55 up to some of the tactile control that it is missing.  E.g. map some knobs to guitar tone, amp tone stack controls, etc.  Then at least for guitar & amp type patches, you'd have tactile control over the basics without kneeling and menu surfing.
Strat w/ GK-3, Godin LGXT
VG-99, GR-55, GP-10
thebrushwithin
Recently I asked this question to Livid's support team:
06/20/2014 3:26 pm
"Before I purchase your new Guitar wing, I need to know if multiple midi channels can be assigned in one setting. I will not be using a computer, except for initial setup. Live, I will have the Wing receiver connected to an iConnect Midi4+, and from there to a Roland VG88, and a Roland GR30. For example, I will be using it for patch changes on two different units. Channel 1 will use some switches, and/or pads to change prests on my Roland Vg88, and channel 2 will use other switches, and/or pads to change patches on my Roland GR30. One of the sliders would control CC#7 on Ch.1, while another slider controls CC#7 on Ch.2. Is this possible?
Thanks,
Mark"
Here is today's reply:
"Off the bat in the initial release, this will not be possible. However, we are going to work quickly to release the editor which will allow you to set different midi channels for different controls."
Great news for anyone who wishes to replace their foot controllers. On my GAS list!!!
I am sooooooo.... tempted...
I noticed in the overview video that Vernon Reid was interviewed to discuss & promote the product!
thebrushwithin
When the editor is fully assignable, I'm going for it!
myksara
Has anyone bought and tried this yet? Looks tempting.
Can this replace FTP?
QuoteHas anyone bought and tried this yet? Looks tempting.
Not the same thing at all
Guitar Wing is a Wireless remote controller that transmits MIDI CC#/Aftertouch Controller messages, and does NOT perform "Guitar to MIDI" function - like the Fishman Tripleplay does
Now_And_Then
#15
 Guitar Wing
I just got an email about this; seems to be a live-performance-oriented software controller meant to be affixed to a guitar and as such it cuts across several subforums here.
(The following is from http://www.perfectcircuitaudio.com/catalog/product/view/id/7874/s/guitar-wing-wireless-control-surface/category/160/ )
The Guitar Wing combines the latest in wireless technology, RGB LED lighting and ultra-thin pressure and touch sensitive controls, for a totally new, completely portable, and elegant design that fits almost any guitar.
The Guitar Wing fits any electric guitar or bass and does not require modifications of your instrument. Easily attached (and removed), it communicates with your computer using wireless technology.
You can use the Guitar Wing with the bundled effects plug-in, WingFX™, or dive into the vast world of software, controlling programs like Logic, Garage Band, Ableton Live, Guitar Rig, Reason, and many others. Whatever your vision, the Guitar Wing provides an expressive control surface that's designed to fit the needs of guitar and bass players.
As a class compliant MIDI device, the Guitar Wing works with almost any audio software, iOS application, VST Plugin and more. Setting up the connection is easy, and with colorful LED feedback, you'll know what's going on without having to look at your computer screen.
Livid Instruments has a growing list of software templates that will be available for Guitar Wing users. Here are a few that will be included upon release: Ableton Live, Guitar Rig, Traktor, Max/MSP, Reason, Logic, WingFX. Templates that are coming soon: Garage Band, Cubase, FL Studio, Studio One, Digital Performer, Bitwig, Reaper, iOS apps, and many more...
Every Guitar Wing will include the Wing FX™ software plug-in, so you can quickly use it to control effects, pitch, filters and more. Built-in motion sensors offer users new ways to control their sound without compromising their play.
WingFX is a software plugin that acts a wireless digital effects rack for Guitar Wing. With several effects designed for optimal use with Guitar Wing's innovative controls, you'll shape your sound in ways you never thought possible. With features like pitch shifting, filters, distortion and sample playback, you can turn your guitar into a multimedia instrument with ease. Use the built in tuner function to tune your guitar and select a visual mode for sound reactive LEDs.
Features
  • 5 Pressure Sensitive Pads
  • 3 Touch Faders
  • 6 Function Buttons
  • 4 Select Switches
  • XYZ Motion Controller (Accelerometer)
  • Wireless (Bluetooth)
  • All RGB Lighting
  • Class Compliant MIDI
  • Wing Editor Application
  • WingFX Multi-Effects Software
And here's a 10% discount coupon code for http://www.perfectcircuitaudio.com valid from 30 Sept 'till 3 Oct.: Enter code "EXTRA10" at checkout. (That code should be good for all purchases at that website, and not merely for "Guitar Wing".)
charrich56
There is a bundle with JamOrigin Midi Guitar software and the Guitar Wing for $250.00.
http://jamorigin.com/portfolio-item/buy-guitar-wing-midi-guitar-bundle/
I am super tempted but need to get the GP-10 first.
charrich56
You know,  with a GK-3,  and a Guitar Wing on a Strat, the guitar really would look like a Borg-o-caster, wouldn't it?    ;D
I want it!
-Charlie
OldGuitarDude
#18
Livid Instruments has finally released the long-awaited Guitar Wing Editor, however it's still a "beta" version. Before the editor can be used a firmware update is required.
Details here:
http://forum.lividinstruments.com/discussion/19050/guitar-wing-editor-beta-release
Video Here:
jassy
Cool hope I can fix with it the somewhat erratic behavior of controls.
Thanks for letting me know.
 http://lividinstruments.com/products/guitar-wing/
A few left here at $130 - wont last long now that the Livid Instruments Guitar Wing Editor is released ( These go for $190 today )
http://www.hellomusic.com/items/livid-guitar-wing-wireless-midi-controller
Overview
What It Is:
The Guitar Wing provides an expressive, MIDI control surface designed for guitar and bass players. It easily attaches to any electric guitar or bass and communicates wirelessly to your computer or USB-MIDI host. You can use the Guitar Wing with the bundled effects plug-in, WingFX™, or dive into the vast world of software, controlling programs like Logic, Garage Band, Ableton Live, Guitar Rig, Reason, and many others.
Wireless
You don't have to worry about wires, adapters, or cables to use your Wing, you have the freedom to move around as you normally would. The Guitar Wing can be easily attached and detached and fits naturally with the way you play.
WingFX
Using the included WingFX effects plugin, you can instantly access and control digital effects at your fingertips. Use it as a standalone application, or as a plug-in for favorite DAW or recording software.
MIDI Control
As a class compliant MIDI device it instantly works with your favorite DAW, iOS device, MIDI hardware and more without drivers or complicated setups. Use it with Ableton, Garage Band, Protools and more.
Integration
The Guitar Wing simply works with any software that supports MIDI. Templates are available for popular software platforms such as Ableton Live, Guitar Rig, Logic, and more. The Guitar Wing can also be used to control MIDI hardware like Axe-FX or Eventide pedals, using your computer and MIDI interface or a USB-MIDI host. Use the Guitar Wing Integration Guide for project templates, setup instructions, and other resources to use Guitar Wing with your favorite music production or DJ software.
Hello Music SKU: LIV-LVGUITARWING01
Specifications
Adhustable non scratch guitar clamp with a rechargeable, 8 hour battery
Safety strap lock
4 side switches
3 led touch faders
3d motion sensor
6 function buttons
5 pressure sensitive pads with velocity & aftertouch
November 11 edited November 11
Hi Tom,
We just released a fix for some of your suggestions.
The links in the original post have been updated to v0.23, which contains the fixes.
Description of Updates
All Systems:
- Added motion icon for modifying gyroscope behavior.
Windows:
- Tabs are now larger and display text properly.
OS X:
- Tabs are now left-aligned.
- Drop-down boxes now display black text.
Ubuntu:
- Build for Ubuntu added to the library.
A couple of the message types in the editor have some hidden functions that you may be looking for.
Assigning a Control as a Pitchbend:
0-15 = Bend Down (Channels 1-16)
16-31 = Bend Full Range (Channels 1-16)
32-47 = Bend Up (Channels 1-16)
Assigning a Switch as a Program Change:
0-125 = Direct Program Change
126 = Program Change Down
127 = Program Change Up
http://forum.lividinstruments.com/discussion/19049/guitar-wing-firmware-update
The Guitar Wing Editor provides a taste of its control possibilities.
(download here)
I actually like the communications debug window that displays all real time communications during Guitar Wing setup
My hardware is not here yet - but here is the Editor screen capture
and the Companion "Wing FX" for Ipad  is now in the App store
https://itunes.apple.com/us/app/wingfx/id918578403?mt=8
WingFX offers instant access to guitar effects, filters, samples, and more. WingFX is specifically designed to match the unique controls on your Livid Instruments Guitar Wing controller - use the Guitar Wing hardware to dynamically control your FX as you play.
Don't have a Guitar Wing? The app is still fully functional and you can interact with the touch screen to control the FX.
Plug in your instrument and headphones, flip the software switch to "On", and start jamming.
You will need audio input to your device as well as headphones.
I was going to try playing around with  Livid Instruments  "Wing FX"  for iPad - but this app is the first Ive seen this error message:
* This application requires iOS 8.0 or Later. *
I'm sticking with iOS 7.1.2 for iPad Air  since I'm not interested in breaking many of my older apps
http://theamazingaudioengine.com/
http://theamazingaudioengine.com/doc/
My Guitar Wing arrives later today!
HelloMusic used Fedex Home as the carrier, and here in my town that is the worst method, they never deliver on Saturdays and don't work on Mondays, so because they insist on my signature, I won't see the Guitar Wing until next Tuesday evening.
FedEx Home sucks!
