VG-8 vs GR-55 How much better is VG-8?
Started by CodeSmart, October 31, 2013, 11:38:05 PM
CodeSmart
I'm postningen this again in the proper section. Anyone with a VG-8 out there? How much better is the emulation compared to GR-55? I've been offered a VG-8 system with extra sound board for abt. $650 USD. When would it be worth that investment?
Many might say the GR-55 sounds better for Electric Guitar and Amp Emulation compared to old VG-8
Remember the 1996 VG-8 ran at 18 bit @ 32kHz , which manifests as less transparent compared to GR-55's 24 bit @ 44.1kHz
https://www.vguitarforums.com/smf/index.php?topic=231.msg699#msg699
The VG-8 is the only unit with "Autotune" - can retune your guitar in the middle of a song, at the expense of Alt Tunings. (On the VG-8 its AutoTune or Alt Tunings - not both)
The VG-8 has unique HRM Models best exhibited by David Coffin's VG-8 patches.
The VG-8 has excellent LCD feedback for patch vs stompbox mode.
The VG-8 is 1996 tech = 18 bit @ 32kHz processing
VG-8 Manual is here:
http://www.roland.co.uk/Support/Downloads_Updates/eula.aspx?Asset=pdf/VG-8_OM.pdf
http://www.roland.co.uk/Support/Downloads_Updates/eula.aspx?Asset=pdf/VG-8EX_OM.pdf
The VG-88 has the Gretsch COSM model, and a Normal 1/4" Guitar Input. (not found on the VG-8) and extensive MIDI Control assignment.
Use the VG-88 Veditor here:
https://www.vguitarforums.com/smf/index.php?action=downloads;cat=20
The VG-88 is circa 2000 tech = 20 bit @ 44.1kHz processing
VG-88 Manual is here:
http://www.roland.co.uk/Support/Downloads_Updates/eula.aspx?Asset=pdf/VG-88_OM.pdf
CodeSmart
I will review the manuals and compare.
Thanx Elantric!
