Question: how to mix external audio in phrase looper
Started by looper, August 22, 2014, 07:38:11 PM
looper
Hello, is there any practical way of sending an external audio (eg microphone) to record along with the phrase looper gr-55 while playing guitar with gk-3?
thanks
looper
Quote from: gumtown on August 22, 2014, 07:41:33 PM
while playing guitar? No
I read some threads where created an extra entry, but I think the sound down to a microphone stand.
looper
Quote from: ronaldo.bc on August 22, 2014, 07:48:11 PM
edit:  I do not know if anyone has done this not read this post because I just could adapt two parallel entries and added a microphone.
Of course it does not have the EQ of a mixer, but to improvise a rhythm style hip-hop already solves.
IF you obtain a small mixer  - you can feed a Mic into its XLR input and then feed output of Mixer into the 1/4" Input on your GK-3 and obtain your desired results.
http://www.bhphotovideo.com/c/product/421979-REG/Behringer_502_XENYX_502_Compact.html
Or perform one of the GR-55 modifications below to feed output of mixer direct into GR-55,   but know this will void your warranty
GR-55 Mods
*  Add a Normal Guitar Input jack on your GR-55
https://www.vguitarforums.com/smf/index.php?topic=4624.0
* DIY GR-55 guitar pickup input output fx loop Mod with Pictures!
https://www.vguitarforums.com/smf/index.php?topic=3994.0
looper
Quote from: Elantric on August 25, 2014, 11:12:39 AM
GR-55 Mods
yes, thanks Elantric,
it should be very good. But how is something temporary, I would not risk it and just created an external box with 3 jack p10 interconnected. There was only plug in the cables.
My idea is to finish building the foot controller with 15 buttons for use with mini ipad. (Loopy HD + DrumPerfect).
