Can someone with a Pod XT Live do a MIDI CC experiment?
Started by paults, February 13, 2011, 03:39:03 PM
paults
I want to send virtual pickup position via pin 9, split it out to an EXP inputon a MIDI controller, and send the MIDI CC into the GR-55.  I can do that with a MIDI Solutions or Rocktron box for about the same money as a used Pod XT Live, and this has a gazillion amp and effects models in it.
The MIDI CC doco for the XT Live indicates it does not send CC info from Pedal 2 input, but elsewhere in the the manual, it shows the pedal can be mappped to functions that do transmit CC values.  And, it says an FVB peal connected to the XT would transmit CC.
If anyone has an XT Live, can you try mapping Pedal 2 to an internal effect parameter (tweak, for example), and let me know if that effect parameter starts sending CC infor when you move the pedal?
Thanks!
